7500 Maint. Service Cost
Old Dec 27, 2001 | 06:38 AM
S2K_Dallas's Avatar
Default 7500 Maint. Service Cost
What did it cost you? I have to do mine soon. What are some of the best prices in Dallas?
Old Dec 27, 2001 | 06:42 AM
Sideways's Avatar
Did it myself. Why pay them big bucks to change the oil?
Old Dec 27, 2001 | 07:09 AM
Bernie Lomax's Avatar
1. change the oil
2. find the procedure for turning off the maint light
3. fill up the washer fluid
All done. And all you spent was about $25.
Old Dec 27, 2001 | 07:52 AM
wanabe's Avatar
dealer gave me 5 free services- so the cost was exactly $0.
they also did the seatbelt recall and wanted to give me a loaner, but since it was not an s car i didnt take it!
Old Dec 27, 2001 | 08:24 AM
turbolane's Avatar
Cost me $29, but I had to turn of the maint. light myself...sigh. (not that was hard, quite easy).
Old Dec 27, 2001 | 09:34 AM
S2K_Dallas's Avatar
Fair enough
Old Dec 27, 2001 | 11:33 AM
Schatten's Avatar
7500 mile maintenance consists of: changing the oil and checking the tire pressures. prices for this have been anywhere from $85 up to $195!
and dont forget to check the faq section for resetting the maintenance required light.
Old Dec 27, 2001 | 01:15 PM
paS2K's Avatar
[QUOTE]Originally posted by Schatten
[B]7500 mile maintenance consists of:
Old Dec 27, 2001 | 01:19 PM
S2K_Dallas's Avatar
I have been quoted a price of $60 for...
Tightening some of the "belts"
Cleaning the Injectors with cleaner they run through them
Oil Change
Battery check
The battery would be checked and the posts "cleaned"- they don't need cleaning. I know I can buy some Fuel Injector cleaner for $8 and do that myself. Not sure about the belts. Should I just have them change the oil? The Maint Schedule says to do the following things...
Oil change
Inspect front/rear brakes for wear or damage, tightness of mounts and caliper leaks
Check tire pressure
Inspect tie rod ends, steering gearbox and rack boots
Inspect suspension components
Inspect driveshaft
None of these things were mentioned in the phone conversation. Is this really a BS service thing. Doesn't seem that they follow it very closely and just change the oil.
Old Dec 27, 2001 | 02:15 PM
wanabe's Avatar
the service manual says to replace engine oil and check tire inflation and condition... for normal conditions.
for severe conditions they also add to check brakes, tie-rods, suspension components, driveshaft boots.
be careful- some dealers might just change the oil and charge for doing all of the above!! if you arent doing it yourself, find a dealer or shop that you can trust...
