About to change ALL my fluids
Old May 27, 2007 | 04:44 PM
duality's Avatar
Default About to change ALL my fluids
I tried searching and it was just way too complicated given the software this forum uses.
Will someone please tell me which fluids to use...
engine oil:
coolant:
transmission:
differental:
muffler: jk
any other fluids to change?
Old May 27, 2007 | 04:49 PM
chino101's Avatar
Here's a good place to start.
https://www.s2ki.com/forums/index.php?showtopic=108435
Old May 27, 2007 | 04:59 PM
duality's Avatar
ok that all just confused me. I know how to open/drain/flush/close things but I just was wondering what weights and brands everybody liked.
Old May 27, 2007 | 05:04 PM
chino101's Avatar
opps.....I meant to put this one:
https://www.s2ki.com/forums/index.php?showtopic=195574
I'm personally using:
Engine: Havoline 10W-30 Conventional
Coolant: Honda Brand
Oil Filter: Honda Brand
Diff: LE607
Trans. Honda MTF Green Label
Old May 27, 2007 | 05:08 PM
NFRs2000NYC's Avatar
Here is what I use, and have had stellar results. Ive tried all the high end fluids, and these worked the best.
Motor: Amsoil 10W30 Synthetic
Trans: Amsoil MTF
Diff: LE
Clutch: ATE
Radiator:Honda
Oil Filter: Amsoil EAO20
Old May 27, 2007 | 05:16 PM
CKit's Avatar
Motor: Mobil 1 synthetic
Trans: GM synchromesh
Diff: Amsoil LE-607
Old May 27, 2007 | 05:43 PM
duality's Avatar
Trans: Amsoil MTF
Diff: LE
Clutch: ATE
Radiator:Honda
thanks dude!!!
Old May 27, 2007 | 06:42 PM
RedY2KS2k's Avatar
I'd also flush the brake fluid. It absorbs water from the air, and water is corrosive to iron/steel. Any brand-name DOT3 fluid will work for the brakes and clutch. A quart(liter) is enough to do both.
Old May 27, 2007 | 07:23 PM
SenderGreen's Avatar
Make sure you flush your coolant. MY2000 came with type1 Coolant (discontinued). You'll be replacing it with Honda type2 coolant. Flush it to be safe unless you've done it before. I agree with the above, flush/beed your clutch. Check the throttle cable for slack/deflection. Take out the slack, but not all of it. There should be between 2-4mm deflection if memory serves. Check your air filter. Good Luck
EDIT: I use:
Oil= Honda 10w-30
Oil Filter= (only)Honda PCX oil filter. Torque to 16ft lbs. or 7/8ths of a turn after the filter seats on the block. No exceptions, tight enough is not tight enough on an S2000 block.
Coolant= (only) Honda Type2
Transmission= New Honda MTF (green label)
Brakes/Clutch =Honda DOT3
Diff= LE-607 (never let the dealer provide diff fluid, Honda dosen't have one and they have screwed up more than couple times I've seen on here.)
Rubber seals= Shin Etsu (Honda sourced Silicone Grease)
Old May 27, 2007 | 11:39 PM
NNY S2k's Avatar
Oil-Mobile 1
Tranny-Honda mtf
Dif- Mobile 1 gear lube
