Accident...taken care of
well....depending on how much it would cost to get everything repaired would sway my choice either way.Don't think your insurance would go up for that type of accident also...not sure.It's not like it happened because you are a careless driver.just one of those things you couldn't avoid,it was raining and you couldn't see the puddle...
Possibly more bad news, if you are saying your car just had it's first oil change with 1,900 miles on the odometer total then it may be too soon. I don't think it has changed from generation to generation, so as far as I know Honda says not to change out the factory oil for around 5,000 miles. Supposedly there is an additive in the factory fill oil which helps the rings on the pistons to seat properly. I may be off on the terminology, if thats the case I'm sure someone will correct me. In any event good luck.
what oil did you put in?and regarding your accident, most reputable bodyshops will give free estimates. Go get one and weigh up your options. I wouldnt worry about a wheel thoough, you can get those cheap enough on here or ebay.
I was under the impression Honda doesn't want us to change our oil until 7500-10,000mi. This is what I think I read. And if you need to before then, you need to use their oil with the additives. Because it helps seal everything up. There has been a lot of talk about this. Anyone know the actual page in the owners manual it talks about this? I will have to go look.
As far as the damage to the wheel - you most likley bent the suspension too if you hit hard enough to bend the wheel. Call your insurer and get a claim filed.
Andrew
Originally Posted by aklucsarits,Jan 10 2006, 01:12 PM
It's a myth. It does no harm to change your oil too soon. IMHO, it's better to get the 1st oil change done early anyway to get all the metal particulates, casting sand, etc out of there as soon as possible. There is no magical Honda oil.
Andrew
Andrew
If you plan on selling your car before 90k miles, I guess you would never know the difference though I'm sure the seals and the tollerances wouldn't be as good as a car that was broken in properly.
Dino oil breaks down fairly quickly compared to Synthetic oil. I would personally change off of the "break-in" oil after 3500 miles or 6 months, whichever is sooner.
However, since the S2000 engine seems to need about 10,000 miles to fully break in, I would not switch to synthetic until at least 10,000 miles and I would also add a quart of Valvoline Maxlife which has been noted in the oil journals to have a similar moly count as the Honda break-in oil.
