Advice on buying a 2001 S2000
I'm sure you've seen a zillion of these newbie questions but I would appreciate some advice.
I test drove a mint condition 2001 S2000 with under 18K miles. I'm very impressed overall with the car. The one thing I found disconcerting was the sound of the engine. Sure, I've read a number of comments about the hi-revving S2000 -- it's the stuff of legend. I'm curious what's a normal cruising RPM?
My experience on the test drive was the entire time the car sounded like a normal car would wound to red line. The 'buzz' did drop down to a bit under 4k RPMs for the brief spell I popped it into 6th. But by then I was at 75.
I've never driven a car like it so I'm not sure what to expect. Thanks for any advice/insights you can offer.
Speed when engine is at 3,000 RPM in sixth gear: 55 MPH (give or take a little)
(it's a high rev engine...have no worries; it was designed that way. Although, I would get a 2002 or higher
[QUOTE=Hate Me,Aug 13 2004, 07:25 PM]Speed when engine is at 3,000 RPM in sixth gear: 55 MPH (give or take a little)
Originally Posted by cbanks,Aug 13 2004, 08:56 PM
What makes a 2002 significantly better? Does the 2001 have problems or reliability issues?
Thanks in advance for any advice you can give me.
Originally Posted by neeks127,Aug 14 2004, 02:57 AM
02 has rear glass window and electronic defroser, softer suspesion, better transmission and sound system. other than that, they are pretty much the same.
oh and bigger H emblem....
It's VINYL, not LEATHER.
the only real differences are the glass window and the cheapass tweeters in the doors (if you cared about that, you'd probably have aftermarket speakers anyway). I don't know what the tranny differences are, must be a slight revision because the gear ratios are the same.
