AEM plug & play programmable EMS
Old Oct 10, 2003 | 06:25 AM
vassosva's Avatar
Default AEM plug & play programmable EMS
Hi this is Vassos I am thinking of installing to my S2000 the AEM plug & play programmable EMS have any of you tray it what is your opinion to go for it , do you have any suggestions or arguments about it .I am waiting for your answers
Thank you
Old Oct 10, 2003 | 06:27 AM
3ngin33r1's Avatar
It's not plug & play. They say it is, but you'll need to do some configuring.
What mods are you currently running and what are you looking to do with the AEM that you can't now?
Old Oct 10, 2003 | 06:29 AM
Hobbyholic's Avatar
It takes alot to tune the AEM. I got a quote from tourque freaks and it is about $1200.00 to tune.. Good luck..
Old Oct 10, 2003 | 07:23 AM
vassosva's Avatar
my car is completely stock at the moment. if by installing later on different mods on my car , will the AEM management be easily reprogrammed ?
Old Oct 10, 2003 | 07:52 AM
vassosva's Avatar
What do you mean by doing some configuring?
Old Oct 10, 2003 | 07:55 AM
AndyP's Avatar
If your car is stock, the EMS is overkill.
Most EMS users have extreme setups like high boost Turbo and Supercharger applications or even very high compression NA setups. If you just plan on doing minor bolt ons and want to re-tune, go for the Apex VAFC.
Old Oct 10, 2003 | 08:44 AM
3ngin33r1's Avatar
As AndyP said, the EMS is overkill, when you go turbo/SC and get some bigger injectors go with the EMS.
Until then, the VAFC will do fine for you if you want to tweak out stock power.
Old Oct 10, 2003 | 08:50 AM
vassosva's Avatar
I was thinking of using a piggyback but then I saw the AEM EMS and it sound more safe because it is manufactured for the car it self than to use any other electronic system that is not programmable for the car.
I also have in mind to make some other changes to the car in the future.
Old Oct 10, 2003 | 08:52 AM
3ngin33r1's Avatar
What are your future plans?
Old Oct 10, 2003 | 09:03 AM
vassosva's Avatar
To change the valve set with one with high compression valves the valve spring set, retainers and the head gasket
