Aftermarket Differentials for S2000s?
Originally Posted by negcamber,Nov 27 2007, 08:01 PM
And if you lift a rear wheel under hard cornering the Torsen LSD won't work...sends power to the lifted wheel.
Thats why you see people using those 1.5-way LSDs. Those will lock harder and differently. It takes some getting used to (as the car reacts different during hard turns). Also, those LSDs require maintenance from time to time. Torsen LSDs don't require much maintenaince
Originally Posted by penguins2001,Nov 27 2007, 08:10 PM
if honda put a 400hp motor in the car the diff would be able to take it
you dont make a light car by over designing parts
i never said gm was capable of designing anything
... I was just pointing out that the factory diff is basically perfect for a factory motor (or most na upgrades) my car is making 227 at the wheels on a dyno dynamics dyno (197 stock) and i have had no problems with my diff, to give you an idea of how hard i drive my car i have gone through two sets of tires in the last 8000 miles... when my rears are worn to the point i wont drive with them in the rain anymore i take my car to a parking lot and practice drifting until cords are showing
if you diff breaks on a stock or close to stock car on an s2000 you either didnt change the oil soon enough or you need to learn how to drive
... I was just pointing out that the factory diff is basically perfect for a factory motor (or most na upgrades) my car is making 227 at the wheels on a dyno dynamics dyno (197 stock) and i have had no problems with my diff, to give you an idea of how hard i drive my car i have gone through two sets of tires in the last 8000 miles... when my rears are worn to the point i wont drive with them in the rain anymore i take my car to a parking lot and practice drifting until cords are showingif you diff breaks on a stock or close to stock car on an s2000 you either didnt change the oil soon enough or you need to learn how to drive
