Aftermarket radio wiring mess!
Old Apr 10, 2021 | 01:49 PM
Cheedren's Avatar
Default Aftermarket radio wiring mess!
I hate wiring! I attempted to install an aftermarket radio which was unsuccessful. I had to splice into two wires in the back of the OEM radio harness Pin 3 and Pin 14 I believe. It didn't work probably because of something I did wrong. I undid everything and put it back to original but now my soft top is stuck down and I cant put it back up. Im assuming its a blown fuse? I have almost no knowledge on wiring, so assume stoooopid.
When flipping the switch forward I don't hear any noise from the motors whatsoever. So far as I can tell everything else seems to be functioning. Windows roll up, hazards function, the radio works.
Can you tell me where exactly the fuse for that would be and how I could check it with a multimeter?
Thanks!
PS. I took it to a Honda dealership and the diagnostic was $480 not including the fix...
Old Apr 10, 2021 | 02:10 PM
Zer0ne's Avatar
Fusebox diagram #12 is soft top
Old Apr 10, 2021 | 05:08 PM
s2kfast's Avatar
Just buy the harness from modifry. Expensive but worth to avoid hassle splicing
Old Apr 11, 2021 | 10:37 AM
cosmomiller's Avatar
Top Answer: 1
Not only should you take the advice of s2kfast, you should also get Modifry's PNP harness that makes the dash controls work as well. Soooo much easier. I put in a Sony and my only real concern was making sure it fit (thank you Crutchfields). It was tight but the Modifry harness really helped.
Old Apr 11, 2021 | 01:41 PM
Cheedren's Avatar
I managed to fix the soft top issue, turns out the i got the switches mixed up with the defogger. However, I bought a Pioneer MVH-S522BS and bought Metra 70-1721 Receiver Wiring Harness and Axxess ASWC-1 Steering Wheel Control Adapter. I've never heard of Modifry. Which parts do i need to get the DCI and radio to hook up without splicing?
Old Apr 12, 2021 | 06:27 AM
Monopoly's Avatar
Just get Modifry w/DCI. I just installed it last week and havent done a car stereo in 15 years. It literally look me 20mins. The harness and instructions include was plug and play. Everything works perfect no splicing or messy issues to worry about. I went with a Alpine deck w/Bluetooth.
Old Apr 12, 2021 | 07:42 AM
hatsubai's Avatar
Go here:
https://modifry.com/index.php?route=...&product_id=60
Select:
* Head Unit: Pioneer
* Harness: PnP Adapter Harness
It will be 100% plug and play from there on out for your Pioneer HU.
Old Apr 12, 2021 | 09:11 PM
Cheedren's Avatar
Sounds good! I purchased the kit with the DCI controller as well. Thanks for the help!
S2Kawaii
Nov 22, 2015 01:07 PM
luchini
Oct 22, 2015 10:15 PM
