The ALEX engine torque damper
Old Dec 31, 2004 | 04:44 PM
deepee's Avatar
Default The ALEX engine torque damper
The Alex Engine Torque Damper reduces engine movement under on/off throttle conditions such as gear shifts. Consequently, engine power is more directly transferred the wheels and wheel hop is reduced. The reduction of wheel hop is particularly noticeable on the RSX's first to second gear shift. The torque damper is made from CNC aluminum and chromoly steel. The damper itself consists of ABS plastic enclosed in a CNC aluminum sleeve. The plastic is compressed upon when the engine moves under load. The torque damper is compatible with engine mount upgrades and is highly recommended for high horsepower cars.
*EP3 application requires drilling of holes
HONDA
S2000 00+ AP1 Requires Modification $355cdn / $268usd
**info & pic copied from Aj-racing.com**
So...does anybody have this? how is it compared to J's Racing engine damper? It sounds like the J's use nylon for flexing and these use plastic...is that the only major difference? i like the "tein-looking" green better than orange...
Alex or J's?
Old Jan 1, 2005 | 09:18 PM
NFRs2000NYC's Avatar
I dont have one, but I will vouch they make a BIIIIIIIIG difference. HUGE difference. I installed one in my friend;s RSX and the difference is big. The motor vibrations are greater while standing still, but MUCH less when you are moving.
Old Jan 1, 2005 | 10:35 PM
Fast Shadow's Avatar
Keep in mind the differences you felt on an RSX may have to do with it being FWD. The device pictured sure looks like it's based on a steering damper you'd find on a sportbike..
Old Jan 2, 2005 | 06:01 PM
The wheels driven do not matter with engine dampers. The engine will move a little bit, regardless of what wheels are driven. The one on the RSX looks the same, except its gold.
Old Jan 2, 2005 | 06:07 PM
Slows2k's Avatar
Except for green anodizing instead of gold, the Alex damper appears to be identical to a J's piece. I bet they are made by the same supplier for both.
SpeedxRacer's Avatar
5zigen makes one too for our cars... the thing is I cant find a single pic of the 5zigen one.
Old Jan 2, 2005 | 07:37 PM
ideugene's Avatar
I was considering this... but was turned off by stories of the j's not fitting right. I wonder how these fit.
Old Jan 3, 2005 | 12:06 AM
wows2k's Avatar
J'S RACING M4D TYT3! EVERYTING ELSE JUST WANABE!!!111!
Old Jan 3, 2005 | 12:07 AM
S2X's Avatar
S2X
Former Sponsor
for the J's racing torque dampner/heatshield, you'll need some adjusting at least for my MY02. i've adjusted the heatshield to fit and also the ac line. easy to install but time consuming for the fittings. it's a world of difference with them dampners.
picky...
Old Jan 3, 2005 | 08:00 AM
lig's Avatar
lig
wheelhop? torque? not things I really associate with my S2000.
