Alignment - Rear toe in 1/4" = 0.24
Old Feb 5, 2001 | 05:03 PM
Master Apex's Avatar
I had a 4-wheel aligment today however I am not sure that the tech is translating the spec. correctly.
The Hunter equipment he used to align my car can only take inputs in degree (
Old Feb 5, 2001 | 05:52 PM
cdelena's Avatar
That is correct, and it does appear on the Hunter read out (at least the one I have) without negative signs even though it is rear toe in.
I questioned the mechanic numerous times and he apologized that he had to use degrees rather than linier measurements, but assured me it was toe in. Mine is a hair off reading .14 degrees on the left and .15 degrees right for a total toe of .29 degrees.
I had a thread with a long tale of hours long sessions sitting in the car to get an alignment.. most of the delay due to 1) the Hunter machine needing a software upgrade, and 2) the mechanic not being familiar with operating the computer for custom alignments.
Old Feb 5, 2001 | 05:58 PM
RT's Avatar
RT
So the linear readings are taken at 5' (60")?
Old Feb 5, 2001 | 06:48 PM
Thanks Chris.
You gave a me a peace of mind.
I still don't understand how 1/4" toe in is equal to +0.24
Old Feb 5, 2001 | 07:02 PM
cdelena's Avatar
OK, I'll give you the spelling of linear, but how do you get 5 feet?
[QUOTE]Originally posted by asin
[B]I still don't understand how 1/4" toe in is equal to +0.24
Old Feb 5, 2001 | 07:18 PM
Chris,
I am sorry for asking this ...but I want to confirm your definition of total spec is not total toe.
My alignment print-outs is 0.24
Old Feb 5, 2001 | 07:43 PM
cdelena's Avatar
In my limited experience in working with the tech and the Hunter machine, I saw that they can specify the units of measurement (except linear failed to work), display precision, tolerance margin, and a few other things. As a result our printouts may not be showing the exactly the same thing.
When the tech failed to make linear measurements work on the machine for the second time I gave up and told him to just use the machine specified value for toe. I thought he told me it was .28 degrees, but when you said 24 I figured I just remembered wrong.
The sheet I have shows three values for each setting and I am making assumptions regarding what they mean based upon knowing what I asked for and what is specified in the book.
Old Feb 5, 2001 | 07:49 PM
Utah S2K's Avatar
In closing....the Hunter machine is the finest in the world today. If you technician has anything more then an eighth grade education, the level the manual's written too, your alignment is good. The Hunter is unreal!...........but if your tech says......DuH..What's a negative camber...LOOK OUT!
Old Feb 5, 2001 | 08:30 PM
I don't think talking to the same tech (Honda Dealer)who just did my alignment will tell me anything different.
It appears that your rear-toe settings is half of mine.
We could trade car at TWS to see how they handle.
Honda specs for Rear toe is toe-in 6mm or 1/4inch for each wheel:
My alignment tech translates 6mm toe-in as 0.24
Old Feb 5, 2001 | 10:54 PM
RT's Avatar
RT
TRIG relived (sorry, hope this doesn't give anybody nightmares):
Assuming your 0.24
