antenna was painted over
Old Aug 16, 2008 | 10:50 PM
sbrodacz's Avatar
Banned
Default antenna was painted over
I guess the guy who has my s2000 before me did not like using the radio. He removed the antenna and painted over it. I have no antenna nor to I have a spot for one to be. What should I do? Take it to honda and have them install a new one? Any ideas? The radio is horrible!
Old Aug 16, 2008 | 11:13 PM
f23power's Avatar
im a little confused as to whats going on...so the previous owner had the antenna and the base for the antenna shaved? if thats the case..i'd say leave it..the s2000 looks a lot cleaner without the antenna.
you can pull back on the trunk liner and attach an antenna and put the liner back on...that way you will have reception
-a
Old Aug 16, 2008 | 11:55 PM
sbrodacz's Avatar
Banned
I really just want the reception. I'll get reception by leaving the antenna in the trunk behind the liner? It does look a lot better, but I'd like to be able to use my radio.
Old Aug 17, 2008 | 12:01 AM
Ferboi's Avatar
i think you can attach it behind the liner as was stated before, imo no antenna is hella clean. my car has a huge antenna and when i put it on it looks like a complete RC car haha
Old Aug 17, 2008 | 12:03 AM
sbrodacz's Avatar
Banned
I'll give that a shot. Is the cable for the antenna on the driver side or the passenger side? Do you know if autozone or napa sells them?
Old Aug 17, 2008 | 04:55 AM
Sikocivic's Avatar
Check on some "Street Rod" web sites. There are some companies that make hidden antennas that get very good reception.
Old Aug 17, 2008 | 06:28 AM
S~Factor's Avatar
Place the OEM antenna and all the wirings inside the cabin (next to the passenger side seatbelt) for best reception. For a cleaner look, use an aftermarket internal antenna.
Old Aug 17, 2008 | 06:31 AM
f23power's Avatar
antenna is located on the passenger side.
-a
Old Aug 17, 2008 | 07:43 AM
negcamber's Avatar
Get XM/Sirius and forget about FM.
Just putting the antenna in the trunk should work, but if you want something else, you can also look at getting a windshield with an internal antenna. Replacing the windshield would probably be the same cost as un-shaving the antenna.
Old Aug 17, 2008 | 09:03 AM
energetic's Avatar
Get an internal antenna that attaches to the windscreen. It is not visible.
http://www.techgsm.gr/Car_ant_glue_to_wind...T002,26602.html
