anti fouler
Old Nov 8, 2007 | 10:05 AM
HMFIC's Avatar
Default anti fouler
Ok guys.........before i get flamed for this, i checked over and over ive seen the many posts ABOUT the anti fouler and what they do, BUT where do i buy it? hahaha
hopefully this is gonna be a quick ass whoopen and closed =P.. be gentle
Old Nov 8, 2007 | 10:32 AM
highwaystardoritos's Avatar
get them here
Old Nov 8, 2007 | 10:39 AM
rnye's Avatar
Haha ass. Mine doesn't work - Stupid CEL. I need a fix.
Old Nov 8, 2007 | 11:02 AM
HMFIC's Avatar
hahahaha.......Thanks.......that was a good one.
So i take it any auto store?
what does it look like? so its actually to fit for a spark plug? and just screws right in the 02 sensor part and the o2 sensor itself just screws in the fouler which screws in the 02 sensor whole on the test pipe?
Old Nov 8, 2007 | 11:12 AM
thatsahonda's Avatar
spark plug spacer, they come usually 2 in a pack
Old Nov 8, 2007 | 11:13 AM
do you have one or two screwed in? I had one for a while and it didn't work until I put the second one in.
Old Nov 8, 2007 | 11:23 AM
rnye's Avatar
Just one. I guess I need to go pickup a second one. Its weird, itll go on and off for a while. Depends on the mood the cars in, but its an O2 code.
Old Nov 8, 2007 | 12:11 PM
HMFIC's Avatar
really? so 2 come in a pack? should i just be safe and put them together and then into the hole with the 02 sensor in the first one?
Old Nov 8, 2007 | 12:27 PM
JS2k.com's Avatar
Sponsor
Autozone. Part is made by Help!
It is a spark plug defouler. Make sure to buy the 18mm long tapered. Drill through the defouler with a 1/2 in drill bit. Drill only one. Screw the O2 sensor into the drilled one then into the non drilled one.
Or I believe you can just wire a resistor onto the sensor, then you'll never get a CEL from the O2 sensor.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Nov 8, 2007 | 12:54 PM
HMFIC's Avatar
i thougth they already have a hole in it already? just make it bigger to a size of a 1/2 inch you mean?
Then just screw that into the other one? and into the bung right?
then after thats in there.....screw the 02 sensor into the whole thing?
