any inexpensive mods to improve torque?
Old Jun 22, 2007 | 01:55 AM
  #31
s2k_dreams's Avatar
Originally Posted by DarkShade9,Jun 22 2007, 02:24 AM
Speaking of exhausts, aren't there any out there that aren't obnoxiously large tipped? Sometimes I see these $1000+ exhaust systems and it looks like they welded a Folgers coffee can at the end and for some reason it looks really tacky.
/offtopic
J's
Old Jun 22, 2007 | 01:56 AM
  #32
OCMusicJunkie's Avatar
/offtopic
Lots of exhausts don't have tips much larger than standard AP2 tips. It's just hard with a 70mm exhaust NOT to have a large tip. What about J's? They aren't my style, but they don't seem very overstated.
Old Jun 22, 2007 | 02:07 AM
  #33
s2k_dreams's Avatar
He asked what exhausts don't have bazookas at the end, I responded J's.
Old Jun 22, 2007 | 02:16 AM
  #34
dmw16's Avatar
I didn't see anyone mention this, but since you have a 2001 you may benefit to going to a 2002 or 2003 ECU. I found one on car-part.com for $150 then had the dealership reprogram it (due to the immobilizer) so that was $120. So for $270 you get a bit better low and mid range power.
The 2002 and 2003 ECUs are tuned less conservatively than the 2000 and 2001 ECUs.
Old Jun 22, 2007 | 07:14 AM
  #35
TheCarGuy2021's Avatar
Save a couple bucks and get gears.
Old Jun 22, 2007 | 07:45 AM
  #36
dolebludger's Avatar
You may be getting the idea that there is no way to significantly increase torque in the ap1, and that is pretty much correct. Gears are a good idea for making the most of the torque you have.
I went the intake route and made the unit shown and described in the forum thread on the link below:
https://www.s2ki.com/forums/index.php?showt...&#entry10127498
It allows for starting out in first at a lower rpm, and provides noticeably more power in the 4K to 6K rpm range (pre-VTEC), eliminates heat soak, and gives slightly better fuel economy. Cost for all components, including a second stock air box to modify so I could return to stock quickly) was about $300. It has not been on a dyno, so I'm going by feel and a few timed runs between various speeds when I say it improves performance. As you will see, "ram air" plays a role in this mod, and this can't be truely duplicated on a dyno.
Old Jun 22, 2007 | 08:45 AM
  #37
JimmyB's Avatar
I have been reading this thread and something that was written created my question. I have had my car for 5 years and now have about 31K miles on it. I purchased it used, the previous owner installed a K&N filter. I installed a snorkle intake that has been in the car for 5 years and a cooling plate. I also have a 70mm TB and have a 2nd stock intake manifold that is being ported and polished. When I installed the TB I noticed that the TB was fairly clean as well as the intake.
My question is: What type of supposed damage to the MAP or other sensors would be caused by this filter? I don't remeber reading this subject on this subject. I am not questioning the validity of the statement, I just want to know how it damages and what damage it causes.
Old Jun 22, 2007 | 09:13 AM
  #38
screaminyellow's Avatar
Some people believe the oil from the K&N filter will clog up the map sensor and make it fail. If this were true the all our map sensors would fail because we suck in a little bit of oil from the valve cover all the time and that would cause a failure faster. I think this myth was started because the oil from the filter can build up over time on a MAF sensors heated element and cause it not to register properly thereby screwing up a $600 sensor. But since our cars do not have a MAF sensor, there is nothing to worry about.
Old Jun 22, 2007 | 09:16 AM
  #39
gosixers215's Avatar
VAFC and tune? Wouldn't that run a little less than or right around $500?
Old Jun 22, 2007 | 10:09 AM
  #40
DarkShade9's Avatar
I think it's safe to say you won't get much out of this car for $500. You can't even get a decent set of rims without going over a grand.
