Any Plastic to glass top conversion drawbacks?
I've noticed a lot of cars on the used car market these days that have had the plastic to glass top conversion done. Often times it is within a matter of months before the vehicle is offered for sale. Just curious if there are any drawbacks to this modification, maybe material for the top is a compromise from OEM spec and leaves the owner dissatisfied? Or is this a "modification/upgrade" done for purposes to make an easier resale (even though it can be a costly one)?
I converted mine a few years back, the large plastic window was nice, but you adapt to the small glass window. The one thing I do miss is being able to un zip the back window for the extra flow, but thats okay.
you could unzip the plastic window??? I had no clue!
Another member and I just did a complete frame/top swap for mine. I bought his 05 top and frame off him and I love it! I can actually see through the back window now!
Originally Posted by Burgman,Jul 15 2008, 07:47 PM
I believe the glass window is smaller than the plastic so a bigger blind-spot would be the biggest drawback of the glass window.
I am glad I got glass though
Outside of your car, If you put your hand under flap where the rear window is, you should feel some foam rubber tape or a zipper. Once you remove the tape you will find some velcro inside of the car where the zipper is, you will have to seperate the velcro to unzip it.
