any suggestions
Old Sep 16, 2008 | 11:42 AM
silverstoneS2's Avatar
Default any suggestions
every time i take off from a stop the car burps blue smoke out of the exhaust, also on hot starts the engine has a pretty noticable tap. does anyone know what this could be?
Old Sep 16, 2008 | 11:57 AM
Saki GT's Avatar
First, how much oil is in the engine?
Old Sep 16, 2008 | 12:02 PM
Ted H's Avatar
Oil? It needs oil? Oh Sh_t.
Old Sep 16, 2008 | 12:21 PM
its a little bit below full i just changed the oil last week.
Old Sep 16, 2008 | 12:30 PM
Penforhire's Avatar
What, exactly, did you use when you changed it? Some of the super lightweight synthetics might not be viscous enough.
Old Sep 16, 2008 | 12:37 PM
i used mobile 1 10w-30 synthetic
Old Sep 16, 2008 | 12:47 PM
s2000cr's Avatar
Correct me if I am wrong, but blue smoke when the oil level and grade are normal is excessive burning of oil in exhaust gasses, correct?
Old Sep 16, 2008 | 12:51 PM
vtec9's Avatar
Blue smoke means oil is leaking past the piston rings and being burned along with the fuel. In addition, you could have fuel leaking in the opposite direction and mixing with oil, decreasing the oil's ability to lubricate. But I'm no mechanic..
Old Sep 16, 2008 | 01:05 PM
MitsukillinS2K's Avatar
valve seals starting to go bad?
Old Sep 16, 2008 | 01:06 PM
N2oExpresS2k's Avatar
Compression/leakdown test ftw.
