Anyone have problems with the hardtop install??? need help/adivice!!!
Old Sep 8, 2002 | 11:07 AM
mwy23's Avatar
got my hardtop from jeff @ ganley, he's cool to work with and got a great deal on my hardtop..
anyways, it seems the weather stripping is pulling away from the hardtop? and air is coming in from the bottom rear of the side windows when i drive. here are pics from the outside.
link to another post where i posted the pics
also was wondering about that gap in the rear if its normal. that is with the levers in the locked position. thanks for all help and advice!!!
mike
Old Sep 8, 2002 | 01:06 PM
xviper's Avatar
1st, that gap is normal, however, it can be made smaller but this needed to be done before you tightened the HT bracket bolts completely. With them loose and the latch NOT latched, you have a helper put some weight down on the HT thus moving the brackets up relative to the top. In this position, you then tighten all the bolts. When you latch the top, you'll notice that the seal along the rear edge compresses more and the gap is less but still there.
As for the window seal, I didn't have this problem with mine. I notice in your post that you "forced" the top to align with the holes in the brackets. This may have caused the top the "narrow" and thus do not rest in a more natural position (ie. closer to the window seals).
As already stated in the other thread, following the downloaded HandA directions step by step is the only way to go. Skipping steps may lead to misalignment issues.
Old Sep 8, 2002 | 06:02 PM
S2002's Avatar
I just got my hardtop and I have the same gaps. I too am experiencing wind noise. Seems to be coming from the bottom rear corner of the windows. Any advice?
Old Sep 8, 2002 | 10:36 PM
mwy23's Avatar
thanks xviper for your help...
i think doing what xviper said..."that gap is normal, however, it can be made smaller but this needed to be done before you tightened the HT bracket bolts completely. With them loose and the latch NOT latched, you have a helper put some weight down on the HT thus moving the brackets up relative to the top. In this position, you then tighten all the bolts. When you latch the top, you'll notice that the seal along the rear edge compresses more and the gap is less but still there." will actually make the air noise go away in my case. this will lower the weather strip down more and shut off the areas were there are holes...i think i'll try doing this next weekend and let you know S2002 what happens. its going to be a pain taking that inner layer thing inside the hardtop off and on again....
but the weather strip stretching away from the HT and exposing some metal is still a mystery to me. xviper said his HT doesn't do that, and i don't think mine should as well. perhaps contact honda about this? would a self-installed HT not be covered under the HT warranty?
Trunkz
Dec 8, 2014 12:38 PM
Gold Sealing
Jan 1, 2009 01:06 PM
nzouk77
Jun 16, 2008 05:48 PM
S2G4life
May 8, 2006 10:05 PM
cornercompacts
Jan 8, 2005 03:20 PM
