AP1 VTEC engagement point.
Originally Posted by S2-3456789-K,Sep 19 2007, 09:13 PM
http://www.hondahookup.com/info/vtec.php
this article also supports that vtec engagement/disengagement is dependent on several variables/inputs.
btw, by my saying that throttle position is a variable, i'm not implying that you need to be in WOT.
Thanks for the dyno plots.
red, for some reason i get the feeling that you're a BIG fan of the centrifugal SC
i trust your experience with the shop manual/testing vtec, and yes it's good to have those factual pieces of information.
i'm not familiar with the actual vtec control system, but i'm almost positive that it's some kind of feedback control system. it might take a honda engineer who is familiar with the design to tell us exactly how that control system works...which kinda makes me want to work for honda!
hopefully the honda plant in ohio will need an electrical engineer in the near future!
Originally Posted by S2-3456789-K,Sep 19 2007, 02:58 PM
^^ isn't vtec disengagement at a lower rpm than vtec engagement? what i'm saying is that from what i've read, vtec engagement and disengagement go through a feedback control system that depend on several inputs including throttle position, rpm, and some other factors. also, i read that in the ap1, shifting into 2nd gear drops you below 6k rpm but based on some of the inputs mentioned earlier, vtec is not disengaged and then engaged again once 6k rpm is reached in 2nd gear.
from experience, when i shift into 2nd, i don't feel a sudden lack of power followed by a sudden gain jump in power.
just my 2 cents of course
The minimum conditions will have to be constants and not variable based on other factors.
Originally Posted by Enthralled,Sep 19 2007, 02:39 AM
I'm not sure about you guys, but my VTEC kicks in at 4.5K
BTW I have an APDeuce.
but hey, just FYI. lates
Perhaps the difference in altitude is causing a difference in oil pressure? At a higher altitude, the oil would not necessarily reach the needed pressure for VTEC engagement till higher RPMs are reached.
This accounts for the shop manual as well as the difference in VTEC engagement at altitude.
I'd have to do the math to figure out how much of an oil pressure difference would be seen at altitude vs sea level.
Originally Posted by Pointblank,Sep 20 2007, 04:15 AM
I'm pretty sure it's 6200rpm
RMX5 - My Shop (Service) Manual says this about testing VTEC engagement:
1. Reset the ECM....
2. Check engine oil level....
3. Warm up to normal operating temp.....
4. ROAD test the vehicle:
Accelerate in 1st gear to an engine speed over 6,000 rpm. Hold for at least 2 seconds.....
This (ROAD test) does lend credit to the fact that at least in the B16A engines, VTEC will not engage if the engine is not under load. They say ROAD test and not just rev at rest. There is no reason why VTEC should or would engage at any RPM if not under load.
