ASM Header Installed and Dyno'd
Originally Posted by shivers,Jun 1 2006, 04:44 AM
I take it this was just a bolt on and run without any tuning??
Originally Posted by tbtak,Jun 1 2006, 08:14 PM
Those gains don't look right you need to get it done by Church Automotive.
Also do you have a EMS on the car?
Originally Posted by Bionic Man,Jun 1 2006, 11:10 PM
No tuning was done. The A/F ratios didn't change much after the header install. So we left them as they were. The dyno runs were done about 2 hours apart on the same day. No test pipe was used.
Was there any expectation that the ASM header was designed for FI applications? I thought it was intended to run with their airbox. Also the Mugen exhaust is designed for NA applications as well.
You would probably see much higher gains with a Toda header and higher flow exhaust+test pipe.
If the header is only showing that much hp gained on forced induction it further confirms that it is almost an exact copy of the toda header. Which yields less then 2hp in n/a form. The mugen exhaust is not getting in the way of the headers performance. The header is just bling and now it has been confirmed. Asm=Toda=bling. In the future if you guys are going to spend that sort of coin, go hytech or burns and get some real power. I wouldn't be surprised if the megan tested the same or higher. At least the header is nice to look at.
