AxialFlow short shifter HELP
i installed the shifter with white lithium grease. i torqued down the base that holds the shaft in place pretty tight. i put the rubber boot made for the axial flow around the base of the shifter. but there is very loud vibration coming from the shifter area above 6,000rpm. i even teflon taped the threads. is it because of my titanium knob? there's nothing else that should vibrate...
thanks
thanks
The short shifter is known to buzz in some cars, and the "plunger" like rubber boot doesn't always solve the problem. You might be able to quiet it with "magic fingers" (do a search) but you may have to choose between returning the shifter or putting up with the buzz.
Originally Posted by nightcrawler7188,Sep 25 2007, 11:04 PM
i'll use it for a few days, then might or might not sell it
thanks Red
thanks Red
