Bad Engine Break in
Old Jan 24, 2008 | 08:25 AM
INTJ's Avatar
This is an emotional debate, not a debate of any facts.
What has failed? How do you know? What diffference does it make?
I have seen engines with redline after building and 3k moderate driving, none burned oil or had magical hp increases.
Ring design, metallurgy, and clearances have all improved dramatically. As long as you don't use synthetic in the first oil (and even that is debatable), you will be fine.
Old Jan 24, 2008 | 08:47 AM
Boofster's Avatar
It says in the manual to do a break in. Honda wouldn't put that in there.
I got mine with 6 miles and would refuse to buy anything with more than 10.
Old Jan 24, 2008 | 08:53 AM
Elistan's Avatar
Got mine with 13 miles, drove it hard from day one. (I think first redline run was at about 60 miles?) After 82k miles, zero issues.
Old Jan 24, 2008 | 10:23 AM
INDYMAC's Avatar
There are those that like to worry about things they can not change, so I would suggest we all leave him alone to sulk...
Old Jan 24, 2008 | 11:11 AM
INTJ's Avatar
How is the GL6 diff fluid workin out for ya?
Old Jan 24, 2008 | 01:29 PM
flag2carrot's Avatar
break in for a new engine does not usually mean that you have to baby it. it actually means that you're supposed to run it under different load conditions. that is, constantly changing engine speed and load induced. my s had 40 mls when i got it, and i'm sure some of them were hard miles. just check the service manual you get - the PID actually requires the mechanic to run the car at all engine speeds.
also, keep in mind that all engines are tested in the factory, some of them in the car, some outside.
here's the bummer though: i used to work for a car manufacturer back in germany - they took every 100th car or so of the line, disconnected the odo and ran it over backroads for 40 mls . after that the car got prepared for delivery and no one could really tell anymore.
Old Jan 24, 2008 | 01:32 PM
txs2knoah's Avatar
the first 20 miles are babied by a honda tech to get the car PDI'd.
the 31 other miles who knows
Old Jan 24, 2008 | 01:38 PM
apexracer's Avatar
I've been to the BMW assembly plant in South Carolina - EVERY car that comes off the line goes through final test which includes a dyno run at various RPM's, speeds, loads, including over 100mph and a run up to redline.
I wouldn't be too concerned about it - especially being a honda
btw - my CR had 3 miles on it when I got it.
Old Jan 24, 2008 | 01:49 PM
CalBear07's Avatar
There is a pretty big debate about engine break-in, but let's just say that many people have driven their s2000s very hard right off the lot and have not had any engine problems up through very high mileages (80k+).
Relax, it's a Honda
Old Jan 24, 2008 | 01:53 PM
Axel6's Avatar
Originally Posted by sleeper_s2k,Jan 24 2008, 06:53 AM
my dealer told me there was no need to break it in, that i could vtec it home. i babied it nonetheless
He apparently never read the manual.
