beeping cluster?
Old Mar 2, 2008 | 12:33 PM
rcodea's Avatar
Default beeping cluster?
'05 motor, '05 cluster...
whats with the beeping cluster? i did notice that my cluster just crossed the 10600 mile marker...is there some kind of a beeping "change your oil morron!" beep? MAKE IT STOP!
its a 2 beep per sec, one second between them, only when moving faster than ~3mph, just started doing it today when pulling out of breakfast. everything seems to be fine, and the AEM ECM is showing that eaverything is alright....
no indicator bulbs in the cluster, so i am working blind here
fuel guage is not wired, and neither is the seat belt switch.
MAKE IT STOP!
Ryan
Old Mar 2, 2008 | 12:36 PM
ashamouel's Avatar
Is your ebrake slightly pulled? One notch?
Old Mar 2, 2008 | 03:45 PM
rcodea's Avatar
i dont think so? is this supposed to cause the beeper to go off when moving?
Ryan
Old Mar 2, 2008 | 04:30 PM
Enthralled's Avatar
yes, it can cause the beeping.
Old Mar 2, 2008 | 04:41 PM
Empedocles99's Avatar
Your description sounds like the ebrake, you maybe pulled it a notch to operate the top?
Old Mar 2, 2008 | 06:10 PM
Vik2000's Avatar
lol
Old Mar 2, 2008 | 06:14 PM
babowc's Avatar
My ebrake was doing the same thing, beeping when I had one notch up.
Old Mar 2, 2008 | 06:27 PM
mikegarrison's Avatar
That's a good feature. It's way too easy to pop up the ebrake in order to raise or lower the top, and then forget to unset it again. I know from experience that the older cars don't have such a warning.
Old Mar 2, 2008 | 06:29 PM
babowc's Avatar
It was actually only doing this when I was driving and had one notch up.
I tested it to see if I can get the top to go up an down while the car is running, at slow speeds, but it kept beeping, so I didn't mess with the top.
Old Mar 2, 2008 | 06:42 PM
nearwater4me's Avatar
Just FYI, the top control module receives speed sensor signals.
The top won't operate when you're moving even if you have the ebrake engaged.
Dan
