believe it or not, this is true!
Old Feb 28, 2004 | 07:27 AM
SocratesDTC's Avatar
hi fellas!
for some strange reason, my friends s2000 (my03) IS STOCK AND PUTS 261.5 PS (FLYWHEEL)
COULD YOU PLEASE EXPLAIN ME THAT? WHERE DID HE FIND +20PS FROM A 100% STOCK S2000???
. . . . . . . = engine stock
___ ___ ___ = engine hot
____________ = engine ~cold
what do you think?
the car was brand new! 5.000 km, the oil hasn't been changed (factory oil), temperature 15-17o C. engine stock
Old Feb 28, 2004 | 07:50 AM
CoralDoc's Avatar
Since dynomometers measure power at the wheels or at the hub, flywheel power is calculated by using a conversion factor. Since flywheel horsepower is not measured directly, perhaps there is some error there. Also, different types of dynomometers yield different results. Finally, there is operator error involved. These can be minimized, but not eliminated.
222 ps (Wheelpower on your chart) = 219 HP. These values are slightly higher than results from Dynopack type dynomometers that measure power at the hub but are pretty high for other types of wheel dynos.
Old Feb 28, 2004 | 07:58 AM
Tsukuba's Avatar
Old Feb 28, 2004 | 08:20 AM
Colardoc,
your reply is well written, I forgot to mention something:
When I heard that, from my friend, I sead "No Way!" . But then he told me that before he dynoed his s2k, another s2k had just dynoed, pulling ~239 hp at the crank (i dont know exactly), which is the standard number for the s2k! So the dynometer works fine.
finally what is going on???
Old Feb 28, 2004 | 10:27 AM
Tsukuba's Avatar
Have your friend Dyno the car again...
Old Feb 28, 2004 | 12:30 PM
Saud2k's Avatar
different dynos lead to different results....dyno another s2k and check out the difference
Old Feb 28, 2004 | 03:20 PM
Big Ben's Avatar
Old Feb 28, 2004 | 07:05 PM
MacGyver's Avatar
How is it this shop is dynoing several S2ks at the crank? I can imagine somene having their engine out of the car for major work, but more than one engine?
Old Feb 28, 2004 | 08:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The crank hp is estimated based on rwhp....
Old Feb 28, 2004 | 08:14 PM
Quik S2K's Avatar
Wait....you dyno'd teh engine when it was cold? I thought there was a rev limiter for cold starts not allowing it over 6K rpms.
