Originally Posted by TomW4
(Post 24464068)
It’s not that the “differential fluid recommendation by LHT was good enough for me but apparently their gearbox recommendation isn’t quite up to that standard”, but more so that I prefer to stick with OEM Honda fluids on everything. Honda provides a transmission fluid for our manual gearbox but Honda doesn’t have any fluid available for our differential. Because of that, I listened to 2 authoritative sources for S2000’s TO ME. I think Billman and LHT both know what they’re doing because of the sheer amount of S2000’s they have worked on. Their recommendation carries a lot of weight FOR ME because I'm not really an expert with fluids and what's best.. Their recommendation for the diff fluid coincides so it carries even more weight. You can do or follow whatever or whoever you want. You are maintaining your car and you should do whatever's best for your situation. If you believe the Royal Purple is what's best for your car then by all means go for it. |
Yep, and their analysis demonstrates this well. Stick to spec.
-- Chuck |
Amsoil 75w140, Puddymod recommended.
Anybody have a replacement part number (Ex. Dorman) for the drain plug gasket, or maybe know the size?
Want to go to Advance or other and buy it. Don’t want to order online or at dealer and have to wait a week to have the car back on the road. |
Diff Oil Mobile 1 #LTC and Billman
Trans Oil Royal Purple #LTH rec Oil pennzoil ultra platinum #2 in the youtube oil test with project farm was my reason for this. Amsoil Won but it will cost me 2 times as much vs pennzoil for something very close to as good. This combo has been working SO SOILD; full 600 mile travel + 30 + laps at the track event i burned 0 oil and had 0 issues. Pretty happy with this combo |
Originally Posted by Redman007
(Post 24463180)
Hi all, I know this has been discussed before , but what would you recommend as the best differential gear oil, a 75w 90 or 75w140? Cheers https://www.motul.com/us/en-US/products/90-pa |
