Best Engine oil
I change my oil every 3750 (or 6 months, whichever is sooner) on my Civic with Mobil 1 oil and filter. Never had a problem. But, it has only 25,000 miles. But every time I change the oil, it comes out dark. Is that bad? Does that mean I have to change my oil more often than that? Should I change it every 500 miles until it comes out clear again? I started using Mobil 1 one since the 10,250 mile oil change.
The first 2 changes were with dyno "brake-in"
oil (if somebody still belive in myths).
Is any of you having the same thing happening to your stooks? Mine only has 2000 miles and it is still clear.
oil (if somebody still belive in myths).Is any of you having the same thing happening to your stooks? Mine only has 2000 miles and it is still clear.
We use a lot of Motul (the French brand) back home though it's a bit on the expensive side... Supposed to be THE best... My turbo cars ate HKS 15W-50.
I have four quarts of redline sitting in my closet now that I plan to try as my first synthetic on the stook at around 4000 miles.
Originally posted by Naka
...every time I change the oil, it comes out dark. Is that bad? Does that mean I have to change my oil more often than that?
Originally posted by firsts2k
Mobil 1...is what I've been using for years.
Mechanics have rebuilt motors with over 100,000 miles and said the inside of the motor is practically new.
Click below for details
Mobil 1
Originally posted by KenS2K
My daily driver ('87 Ford Bronco II) I've always just used Havoline 10w40 with a Fram filter.
Originally posted by pfb
I can't remember all of the details, but remember a consumer reports exhaustive test of oil filters ranked Fram at the very bottom. I recall it was due to minimal amounts of actual filtration material and some cardboard interior pieces that allowed oil to completely bypass the filter under certain conditions...
The following additional information appears on the filter package:
MOBIL 1 HIGH EFFICIENCY OIL FILTER
Superior Technology To Clean Oil Better
This Mobil 1 high efficiency oil filter offers the most advanced filtration technology available. Originally designed for use with Mobil 1 Fully Synthetic Motor Oil, this high-performance filter is also recommended for use with conventional or blended oils to increase efficiency and to provide superior performance at higher oil temperatures and pressures. All new car warranties remain in effect when Mobil 1 oil filters are used. Follow your vehicles manufacturer's recommended oil change intervals.
Synthetic Fiber Content
This Mobil 1 filter element features a synthetic fiber content that gives it one of the highest single-pass efficiency ratings available, with 98% particle removal at 10 to 20 microns. Multiple pass tests using SAE procedure J806 show Mobil 1 oil filters are 95% efficient in removing harmful contaminants from engine oil (conventional filters average 80% efficient).
Low Torque Lubricated Gasket
Mobil 1's low torque gasket is internally lubricated to provide a tight seal and for easy removal. Other features include a smooth shell design that eliminates stress points for increased durability. A heavier canister and backplate construction provides maximum protection against impulse fatigue and stress during cold engine starts. In fact, Mobil 1 filters are designed to withstand five times the normal system operating pressure.
The filter part number for the S2000 is M1-104.
Price is $10.00.
