Best spark plugs
Give that a re-read. What folks are discussing above is accurate. If you use anti-seize and use the OEM recommended torque value, you are actually going to apply MORE force to the plug/threads than desired. So in this case, you would want to reduce your torque wrench target value by 20%.
I'm glad this topic came up as I was generally aware of the no anti-seize note from NGK, but not the reasons why.
Just for grins and giggles, if I recall correctly, Billman had an old head lying around and he decided to conduct an experiment to see how far he could go in torquing a spark plug into the head. He got as far as 65-70 ft/lbs or so if I remember accurately. It was the plug that failed and the head was not damaged or stripped.
Tegiwa Imports
UK & Ireland Traders Forum
20
Jan 16, 2013 11:41 PM
HonCBRf2
Jun 28, 2008 12:42 PM
