Black H emblems
Old Nov 30, 2006 | 03:37 PM
midnightmethane's Avatar
Default Black H emblems
do those emblems (for front and back) have pins and do they come with preapplied adhesive??
otherwise how do you apply adhesive on the back on those badges...can anyone give me a quick how to...thanks in advance
Old Nov 30, 2006 | 03:43 PM
slanguage's Avatar
http://www.ricks2k.com/info/instruct...dgeinstall.pdf
TRY THIS. HOPE IT HELPS
Old Nov 30, 2006 | 03:48 PM
slanguage's Avatar
I believe they do come with either the adhesive and/or pins. It would be stupid to sell them without either of the 2. Might be adhesive considering that's what holds the S2000 onto the fenders
Old Nov 30, 2006 | 03:49 PM
that's great, but i still need to know if the H emblems come with pre-applied adhesive
Old Nov 30, 2006 | 03:55 PM
true...but can i get a definitive answer on what holds the front and back H emblems from hardtop guy...thanks
Old Nov 30, 2006 | 04:03 PM
villain2000's Avatar
Are you talking about the emblems with the solid black backgroumd or the ones witht the open background? The ones with the solid background have pins and double stick tape already applied. The pins are more for just lining up the emblems, though. Its the tape that holds them. i have them, tey are great.. I dont know about the open background ones.
Old Nov 30, 2006 | 04:13 PM
i was refering top the emblems with black background....that's great that they already have the adhesive one em...so it's just align, peel and stick?? that's great and you said the pins don't get snapped into place...but you do have the cut the original clips right??
Old Nov 30, 2006 | 04:28 PM
slanguage's Avatar
the badges come with the adhesive already applied to the back. the link I posted earlier has instructions on how to remove the stock h emblems. no cutting is required i think. put tape around the old badge before removing so you can put the new one in the proper spot. good luck, and hope this helps
Old Nov 30, 2006 | 04:34 PM
Bullitt44's Avatar
Mine from hardtopguy had pins and adhesive! Great pieces, and if you have any questions call Jeff.
Old Nov 30, 2006 | 05:25 PM
Yes, the origionals will have to be cut with a wire cutting tool to help them come off easier.
