blow off valve
Old Jan 21, 2005 | 08:11 AM
bobmoheb's Avatar
Default blow off valve
hey everyone i have an 2004 S with a comptech supercharger and i am getting my 7lb pulley installed today and getting tuning done today also. i was wondering if i should get a better blow off valve like the like the godzilla bov for saftey reasons like someone told me or is it just for the pure sound of it on this kit. also how nice does this blow off valve sound because bov do sound sweet.
Old Jan 21, 2005 | 10:04 AM
FraudulentNeon's Avatar
Banned
I'm not famaliar with the set up, however 7PSI on that sized compressor is not a lot of boost. I doubt you would have any leaking problems. While tuning if you have boost dropping off, or a nice screeching sound your BOV is leaking and you should go for it. If you're into noisemakers and the regular BOV is not leaking, I guess go for it. Sounds like a good way to waste of a few hundred dollars on something that will get annoying.
Old Jan 21, 2005 | 12:22 PM
Search Bar's Avatar
https://www.s2ki.com/forums/index.php?act=S...topics&hl=&st=0
Old Jan 21, 2005 | 04:40 PM
Danyellow02's Avatar
Dan, stop hijacking peoples' threads with your FOR SALE multiple times.
-darkknight1999...
Old Jan 21, 2005 | 04:54 PM
blureds2k's Avatar
Originally Posted by Search Bar,Jan 21 2005, 02:22 PM
HAHAHAHAHA
Thank you whoever you are....
Old Jan 21, 2005 | 05:24 PM
kane.s2k's Avatar
Who ever told you the godzilla would be better for S/C is retarded. The spring in it is too stiff.
Old Jan 21, 2005 | 11:51 PM
revhi's Avatar
How so? The Godzilla will work just as well as anyother one on the market. The only advatage is that it bolts right on the aftercooler. Plus it is pretty loud. The spring is not to stiff, it is adjustable.
Old Jan 22, 2005 | 06:43 AM
kane.s2k's Avatar
The preload is adjustable, not the spring rate. It's too stiff for 7psi. That's really the end of the discussion.
Old Jan 22, 2005 | 06:53 AM
Amer's Avatar
From reading the UTH forum, godzilla is the preferred over anything else.
Old Jan 22, 2005 | 11:17 AM
revhi's Avatar
Please explain why the stiffness makes it bad.
nightcrawler7188
Aug 30, 2008 09:16 PM
BlownAP
Sep 15, 2007 03:22 PM
bobmoheb
Jan 21, 2005 05:58 PM
mikecl713
Jan 31, 2004 10:14 AM
dkhl
Dec 3, 2001 06:02 PM
