Bottoming out
Recently, I've bottomed out a couple of times during spirited driving.
The previous owner had aftermarket 18's installed.
I love em. they are 225/40/18 in the front and 245/40/18 in the rear.
All 3 times i've done it, i was going about 60 mph, hit a dip in teh road, and the front tires tap into the wheel well.
What should i do? I really like these tires, but am worried that one day they will blow or something and ill end up spinning out on the highway.
I'm in Cleveland so bad roads are quite common when i get out of my city (independence, aka "the bubble").
Are there any cheaper springs that are a little stiffer so that they wont dip so much when i hit a spot in the road? i dont want to mess up my handling though. :sigh:
I don't know. I'm going to be switching to winters soon, so it won't matter, but I'm still worried.
Thanks for any help,
-Dan
-Dan
What kind of springs/shocks are you running? If its only springs you might want to do some research on proven springs and shock combinations or coilover setups. I run 18's (225/40/18 front and 255/35/18 rear) and have not been close to bottoming out as of yet. I am running Tein H-tech springs on stock shocks so its a mild drop. All in all, bottoming out is bad and its probably destroying your shocks if they aren't destroyed already.
maybe check to see if you're lowered at all (by the previous owner). i have 18's but i have a stock ride height ('til i put eibachs in) and i have about a 1.75" gap between the top of the tires and the bottom of the fender. my other car is lowered 2" and a sharp dip in the road could slap the undercarriage easily...
with 225/40/18 in front and 245/40/18 in rear, i have about 1.5-1.6 inches between the top of the tire and the wheel well/ fender lining thing... all the way around.
am i lowered?
i hope thats teh case because it would be
if something was broke.
i bought the car used, i think im teh 4th owner. i dont know how to tell if the springs are stock because im not THAT good with cars, and i dont know what the stockies look like.. if someone knows, ill take a pic and post it here.
thanks for the help guys.. please inform me that its because i am lowered
am i lowered?
if something was broke.i bought the car used, i think im teh 4th owner. i dont know how to tell if the springs are stock because im not THAT good with cars, and i dont know what the stockies look like.. if someone knows, ill take a pic and post it here.
Originally Posted by PJCC,Aug 31 2008, 08:51 AM
Sounds like your car's struts are not working.
Sorry, I meant rubbing.
I just said bottoming out because that's kind of what it is. The wheels rub against the fender lining after a big dip in the road at high speed (highway).
It sounds kind of like chirping a tire.
I don't know what the offsets are or what an offset is. I didn't install the wheels; They were on the car when I bought it.
