Brake Fade
Old Jun 20, 2001 | 09:37 PM
y2ks2k's Avatar
Default Brake Fade
After my first track day on my 2001, which consisted of 4 runs at 15 minutes each my brakes feel completely shot on the road. They are extreemly mushy durring normal driving. I have not had them looked at yet but I think I boiled the break fluid (I hope its not the roters or pads). My question is, why would they do this??? My S2000 still only has 2500 miles on it. I would think a car designed for the track would have breaks that lasted a little bit longer under pressure.
Old Jun 20, 2001 | 09:41 PM
Ben's Avatar
Ben
there is a brake group buy to solve this exact problem.
Check the group buy forum, group buy ends very soon.
Also, if you do some searching, there are many, many posts discussing this.
Ben
Old Jun 20, 2001 | 09:51 PM
lvs2k's Avatar
I remember previous post on this forum where the pads were completely gone after a single track day. Based on that, I would say your problem isn't unusual.
Old Jun 20, 2001 | 10:12 PM
gregstevens's Avatar
Banned
No GB is necessary to fix this problem. What you need to do is have high performance brake fluid. It's as simple as that. If you wish to make more modifications to your brakes to add performance, that's fine, they will all help prevent fade. But the VERY FIRST thing to you need to do is go with a high perf DOT 4 fluid. I use and recommend Motul DOT 4 (just bought 4 more bottles of it today, in fact)
It has a high boiling point of 585 degrees and is the singlemost important thing you can do to prevent fade.
If you want to get into different pads, rotors, ducts or stainless steel lines, that is fine, but you MUST start with a high performance brake fluid.
Now, you should flush your entire system of ALL the stock fluid and replace it with some kind of racing fluid if you track the car. If you DON'T get all the old fluid out, you will not get all the benefits of running the more expensive and better performing racing fluid.
Start with fluid, then start doing other things. It's the least expensive and quickest way to obtain excellent results to improve braking and to help prevent fade.
Old Jun 21, 2001 | 12:24 AM
Ben's Avatar
Ben
I'd still recommend searching the archives for further information.
I personally would never again consider racing the S2000 on the track with stock brake pads. I learned my lesson early on, and I've been fortunate enough to help many others in procuring Porterfield pads, (who by the way, all swear by them).
And yes, changing the brake fluid is also highly recommended (and included in the group buy).
Old Jun 21, 2001 | 03:22 AM
CoralDoc's Avatar
Greg gives excellent advise and Ben offers products that will enhance your car's track performance.
After my first track day, my brakes felt as you describe - mushy! The fix was as simple as Greg mentioned - change your brake fluid - do it now! If you plan to use the car on the track, I'd upgrade the fluid to Motul, as Greg recommends, or any other high-perfromance fluid such as Ford Motorsport HD (yes, it works well and is cheap), or Castrol Synpower (the brand that I use). The key is to increase the boiling point of the fluid. Once the fluid boils, air becomes trapped in the lines leading to the mushy feel. I chose Castrol because it has a higher wet boiling point than most other high performance fluids. This means it retains its ability to resist boiling even if it sits in the car for a few months. Other high performance fluids have higher dry boiling points, so resist boiling better as long as you change fluid often.
Although not required to fix your mushy feel problem, I also recommend upgraded pads for track use. I use Porterfield R4S pads and they are great!They improve brake feel and resist fade much better than stock pads, but they create more brake dust. After using up a full set of OEM pads on the Sebring short course in about 3 hours I decided to use Porterfields. I also learned that it is always a good thing to have extra brake pads and fluid at the track just in case.
Here is a link to a previous discussion on brake fluid, pads, etc. http://www.s2000online.com/forums/showthre...hlight=synpower
Keep having fun on the track!
Old Jun 21, 2001 | 03:43 AM
cdelena's Avatar
There are two things that happen to the stock brakes at the track.. brake fade from boiled fluid and brake fade from overheated pads.
The DOT3 fluid in the car is good for the street and absorbs water more slowly than performance fluid but does not do well with high heat. Fluid failure makes for a mushy pedal.
The pads on the car do well until they get overheated. When very hot they lose stopping ability requiring more pedal pressure and producing longer stops. Once cooled the pads will take many stops to clear the baked surface and return to normal.
Replacing both fluid and pads is a good idea if you go to the track often.
Old Jun 24, 2001 | 01:50 PM
gabedude's Avatar
I did the mods backwards in my Prelude. I couldn't find Motul locally when I upgraded the brakes with SS Lines, slotted rotors, and PBR Pads. I tried using Castrol brake fluid. It faded after one 100 mph stop. Scary. Honda fluid faded after a few high speed stops. I put Motul in yesterday and I could not get the fade casued by fluid. My pedal felt the saem the whole time. The pads are another story. The stock honda pads seem better than this crap.
Old Jun 24, 2001 | 06:15 PM
jschmidt's Avatar
The Porterfield R4-S pads are fantastic! In addition to less fade, you'll be amazed at the difference in braking power. I'm now a true believer!
Old Jun 24, 2001 | 07:02 PM
pfb's Avatar
pfb
[QUOTE]Originally posted by Ben
[B]I personally would never again consider racing the S2000 on the track with stock brake pads.
