Brake and Gas Pedal Distance
Old Dec 23, 2000 | 06:49 PM
virgil859's Avatar
Default Brake and Gas Pedal Distance
I drove my first S2000 today and I was totally suprised by the distance between the brake and gas pedal...I wear a size ten shoe and I actually could fit my foot between the two pedals....I have a serious problem driving a manual without being able to blip the gas on downshifts.....I don't have that problem on my miata.....that said I want a blue S2000 very badly...I have one more year on my miata and then I am trading it in....
Scott
Old Dec 23, 2000 | 07:19 PM
wirejock's Avatar
Maybe someone could design a replacement brake pedal for folks with this problem (Mingster?). I haven't driven one yet, but I did sit in one and that was the first thing I checked. Seemed ok to me at the time, but maybe I was a bit excited. Guess I'll find out when Roxanne arrivess.
Old Dec 24, 2000 | 12:44 AM
cthree's Avatar
Administrator
I too notice this problem, I can't get to the throttle without slipping off the brake. Lots have people reported that the placement is perfect and so I assumed it was me. I would very much like a bigger brake pedal, one that extends another 3/4" at least to the right of stock. I haven't measured it.
Old Dec 24, 2000 | 12:46 AM
cthree's Avatar
Administrator
On the other hand, I believe the correct technique is to blip with your heel, and not the side of your foot. No?
Old Dec 24, 2000 | 06:43 AM
GL S2K's Avatar
i'm with you... my last car was a 95 civic si in which i put a momo pedal on the accelerator. heel and toe-ing was second nature with that set up. now, i've switched over to the s2k, and i have to make a concerted effort to have my foot positioned properly before braking. there have been times where i've gone to blip and come up with nothing but air. it would be a shame to cover up that cool-looking pedal with something else, but i'm giving mine about a month more to see if i get accustomed or not.
ps. wirejock, i would venture to guess that it's the accel pedal that would need the mod. brake pedal seems about the right size/place for me.
[This message has been edited by GL S2K (edited December 24, 2000).]
Old Dec 24, 2000 | 09:42 AM
Tedster's Avatar
If you use the ball of your foot on the brake pedal and just rotate your foot, it's no problem to hit the throttle with your heel (and I have small feet).
I prefer this method to using the side of your foot anyway, because this way you can have the ball of your foot planted securely on the brake pedal; less danger of slipping of the brake!
Ted
Old Dec 24, 2000 | 09:54 AM
virgil859's Avatar
Yea everyone has there way of blipping the throttle...there is no incorrect/correct way...I was just amazed...you could always bend the gas pedal...which my friend is going to do...
By the way never bend the brake pedal....
Scott
Old Dec 24, 2000 | 02:57 PM
cdelena's Avatar
I have found that I could
Old Apr 14, 2003 | 07:35 AM
Jim Schweigert's Avatar
The posts in this thread are more than two years old. I still find it difficult to properly fix my heel in place and use the brake as I try to blip the throttle during downshifting under threshhold braking. Does anyone know of an aftermarket brake pedal that reaches further to the right?
Old Apr 14, 2003 | 08:26 AM
Strike's Avatar
The gas pedal can be bent to move it closer to the brake. A couple of us have done this in So. Cal. to make it easier to heel/toe.
