Brakes-everlasting?
It probably depends on the brake pad material too... If we were to just speak generally about pads, I would have to say my Bronco brakes don't last long even when they are cold. Engine braking is more difficult in this thing because of the gearing, and I have to replace pads more often.
Originally Posted by RACER,Jun 7 2005, 08:59 PM
A cars braking system is designed to slow down your vehicle, while a clutch is designed solely to make your car accelerate.
Originally Posted by RACER,Jun 8 2005, 08:46 AM
In the amount of time it takes you to put your foot down on the clutch, change gear, let your foot off the clutch, I will have already out braked you.
Just kidding man.
Originally Posted by RACER,Jun 8 2005, 12:59 AM
Trust me, downshifting at high revs in a weak effort to slow down your automobile will wear out a clutch within 3-4 months.
This is the last time I will reply in this thread. So again, I will ask the question, "which would you rather replace, the clutch, or the brake pads?"
All this talk of wasting a $800.00 clutch to save a $40.00 set of pads
Keep in mind, the compression of the engine will not brake down the speed of your automobile the way your automobile's braking system will slow down your automobile.
That's all I do. Sometimes I come to a complete stop without touching the brakes. 40k miles and the clutch is as week as when I first bought the car.
Originally Posted by YellowS2kPwr,Jun 8 2005, 02:23 AM
Tell you what though... We'll both drive 70 mph side by side... there will be a brick wall in front of us, you use your brakes only, I'll use both engine breaking & my brakes... see what happens
Originally Posted by spidale5,Jun 8 2005, 11:46 AM
You will stop faster if you only have to overcome the momentum of the car. Adding the extra momentum of a turning engine to the momentum of a moving car, during RAPID deceleration, will increase your stopping distance. Correct me if I'm wrong, but I do believe this to be the case.
Originally Posted by YellowS2kPwr,Jun 8 2005, 02:23 PM
You might want to try braking from 80 mph to 0 just by using brakes... and 80 mph by using brakes and 3rd gear 1st.... Just dont lose control of your car by disengaging the clutch too fast
I disagree in fun, no hard feelings!
And I don't think I've ever come anywhere close to losing control of any automobile by disenganging the clutch "too fast".
