Brakes And Rotors
Originally Posted by VAD' date='Mar 15 2007, 09:21 AM
Calipers and rotors are different. Anyway, there would be nothing to gain by using them even if they were interchangeable. If you're looking for some bling, slotted rotors are what I'd use. For pads, either OEM Honda or a good aftermarket ceramic would be good for street applications.
On a higher budget, contact Brembo!
100%The OEM pads are EXCELLENT for a street driven car. For a little bling, go for some powerslot rotors.
Originally Posted by KnowledgeIsPower' date='Mar 15 2007, 10:39 AM
not that i need brakes right now but thats interesting that u can find stuff so cheap from napa. vad do you have any personal experience with those parts you listed on the S? if so whats your input?
Worked great, and it was cheap.
Originally Posted by JayStyles662' date='Mar 15 2007, 09:59 PM
I found a Rotora Brake Upgrade kit on www.importtuninggarage.com any thoughts on that?
Also, the reason I am thinking of the RSX parts is that they are much cheaper and honestly do people really think that Honda didn't use anything from the parts bin for the S2K?
Just my 2 cents
Originally Posted by VAD' date='Mar 15 2007, 09:13 AM
For the dragon, my brakes will be ALL napa stuff. I don't anticipate any issues with them.
thebrakeman.com
if you paint anything power coat and consider temperature requirements
consider ss lines andor new fluid rbf500 (motul)
better life w/ speed bleeders
napa stuff... you got a tractor or something?
Originally Posted by jah' date='Mar 16 2007, 07:52 AM
cobaltfriction.com
thebrakeman.com
thebrakeman.com
How do you get better life of anything with speed bleeders?
A "track" pad, even a "street-oriented" track pad is not better than OEM IMHO. They will chatter and squeal, they will dust like HELL, the dust will generally be corosive to the finish on the wheels, and cold, they will not stop any better than OEM.
DOT4 fluid is also overkill for the street. You have to change it out more often than DOT3 as it is more hydroscopic and will "spoil" from the moisture in the air.
In terms of fade resistance and boiling point:
Fresh DOT4 fluid > Fresh DOT3 Fluid > "spoiled" DOT3 fluid > "spoiled DOT4 fluid.
Unless you are tracking the car (and bleeding the fluid VERY often as a result) you are going to be better off on the street with DOT3 fluid. It will last longer and be more consistant over the long run.
Track parts on the street do NOT always translate, and brakes are one of those things. On the track you are threashold braking ever 5-20 seconds for at least 20 mins at a time. On the street, you might have to threshold brake once a month, MAX, most of the time, even running the Dragon, you should NOT be threshold braking, something should be reserved for a margin of safety. Again, even a backroad or a canyon will not stress the brakes AS MUCH as a track event does.
Sometimes the street setup IS the best choice when you are running ON THE STREET.
