Broadway rearview mirror?
i have searched and did not find any topics in relation to comparisons for these mirrors in relation to mm/length/concave/flat/blue tint?
i noticed some S owners have these and would like to know what your recommendations are, which one is the best for the S, if you have one of these mirrors please let me know what you think of it thanks.
the one i am refereing to clips right on to the stock mirror, some are just longer and have a concave opposed to being flat, i want to order one but don't know which one will give me a better visibility
I had the 270mm wide version. I moved it to my beater CR-V because the way it vibrated too much with bad roads and under hard acceleration.
If you still wanted one I suggest you get the flat version, the wide version will distort distances al la "Objects in rearview mirror may be closer than they appear!"
I use a 270 convex in my 02 and it is OK. It vibrates as others have noted, and when I hit expansion joints on the freeway at speed, it sometimes adjusts itself down due to the weight. The great thing is that the 270 allows you to still use the visors. The 300mm will not and since it is heavier I think it will be even worse as far as vibration. If I had to do it again, I would go with a 240.
HTH
HTH
Originally Posted by C-losAp1,May 23 2005, 06:22 PM
is flat better then concave?
I angle it so it removes my right side blind spot. I have seen some people angle it so they can see themselves
. HTH
