Building a house and I would like to put in a lift..
Does anyone have anything like this: http://www.gesforless.com/default.isg?cPath=11_99
Anyone have a lift in their garage that they can recommend?
Bendpak are well known. You see them on some of the car shows on Spike, Speed and Discovery.
Easiest one to do is the above ground model. You need about 12' of headroom though, just FYI.
Check out www.ultimategarage.com for some more info.
If I were building a new house, I'd get the Flush mount version of the scissors lift as seen here http://www.ultimategarage.com/lifts.htm
Well, if I was building, I'd definitely make my garage ceiling high enough to accomodate a full height lift. Think about it. If you are getting the lift and you can build what you want, why not do it in a way that gives you the ability to store another car as well as being able to work on all your cars. If you get a drive-on lift, I think they also make attachments to lift by the frame so you can work on the suspension.
