buttomed out on speed bump
Old Dec 11, 2013 | 10:48 AM
darkdream's Avatar
Default buttomed out on speed bump
I bottomed out on a speed bump going at a crawl at an angle. I have multiple lowered cars and never bottomed out before, but this speed bump was ridiculously high and steep and I could not reverse with cars behind. I heard the loud thumb as the chassis hit the bump. I only see a small amount of the tar substance scrapped off. Is this to protection the chassis from rust? Where can I find some to reapply to the car? Anything else I should check that is not evident from a quick visual inspection?
Old Dec 11, 2013 | 11:49 PM
ateens4's Avatar
If your car still drives in a straight line, not making odd exhaust noise, or leaking any fluids(motor or transmission oil), then you are fine. I was paranoid when I bottomed out on speed bumps, they're worse than dips and driveways because of the the "metal" sound it makes. Try to avoid speedbumps altogether
Old Dec 20, 2013 | 03:04 PM
alphalanos's Avatar
you can get rubberized undercoating spray at an auto part store. clean the area and spray a few coats and let it dry
s2konroids
Dec 28, 2011 03:09 PM
shur
May 27, 2010 07:20 AM
leets
Socal Swap Meet
Jan 1, 2009 10:23 PM
Kami Speed
Aug 19, 2008 06:37 AM
Notion
Jan 29, 2002 11:59 AM
