a/c delete question?
Old Oct 5, 2005 | 02:37 PM
quickysrt's Avatar
Default a/c delete question?
about to remove the air condition unit.
will the defrosters still work without the a/c? just need to be able to get the morning dew off of the windows in the morning.
-harlow
Old Oct 5, 2005 | 03:04 PM
TR-S2K's Avatar
It still work with temperature set at high and it will take longer to defrost without a/c, because a/c does remove moisture from the air when on.
Old Oct 5, 2005 | 03:10 PM
quickysrt's Avatar
thank you tr.
so basicly just turn on the fan, or heater?
Old Oct 5, 2005 | 03:19 PM
TR-S2K's Avatar
Just turn on the fan and direct the air flow to winshield position, the right most position, and adjust the temperature to red area, it will defrost your windshield, but it will take longer than with a/c on.
Old Oct 5, 2005 | 03:39 PM
mad-dog-one's Avatar
Defrost won't work nearly as well without the A/C.
Old Oct 5, 2005 | 07:52 PM
fastD's Avatar
Not sure why you would want to remove the AC....
Old Oct 6, 2005 | 08:33 AM
TR-S2K's Avatar
To be sure that you can live without A/C, try to re-program the automatic A/C so that you can turn it off in defrost mode. If you are satisfy with defrost performance without A/C and you still like to remove A/C to reduce weight, then it is up to you.
To de-activate automatic A/C:
1) Turn the ignition switch "on", but don't start the car.
2) Turn the fan off.
3) Turn the temperature knob counter-clockwise all the way to the left (blue area).
4) Turn the vent knob to all the way to the left (panel position).
5) Turn the ignition switch "off."
6) Hold down both air re-circulation button and A/C button while turning the ignition switch "on", the orange air re-circulation indicator will start flashing after few seconds.
7) Continue holding both buttons until the orange air re-circulation indicator stops flashing, then let go both buttons.
S2K_Vtec
Jul 9, 2015 11:49 AM
J.nguyen
Socal Swap Meet
Jul 12, 2008 01:55 AM
R3DS2K
May 19, 2008 11:16 AM
