Caliper Paint
Old Mar 8, 2005 | 03:43 AM
S2KNJ's Avatar
Default Caliper Paint
Tell me what works best and where i can pick some up. Need it quick so i can't use the web.
Thanks!
Old Mar 8, 2005 | 04:02 AM
Boston Duce's Avatar
IMO 2 part epoxy caliper paint works best. You can brush it on neatly with an artists' brush, and it lasts forever. With two coats, it rivals powder coating.
Maybe found at race/sports car parts supplier. I know Eastwood's has it, but that would involve shipping.
Pep Boys/ Autozone sell spray hi-temp caliper paint. Some have even used engine enamel too.
You have to mask the bejesus out of the calipers to do a neat job spraying, or you can spray it into the can's cap and brush it on.
It is not as "self-leveling" as the epoxy however, so I found it hard to get a smooth finish using the 'brush' method.
Regards,
BD
Old Mar 8, 2005 | 06:19 AM
Cyclon36's Avatar
Alot of people on this board use the G2 (I think) paint from decalgirl.com
they have a little s2000 logo to put on afterward too. You can find info and instructions here: https://www.s2ki.com/forums/index.php?showtopic=238689
Old Mar 8, 2005 | 06:21 AM
Jason B's Avatar
Check out my write-up here:
https://www.s2ki.com/forums/index.php?showt...9702&hl=caliper
Old Mar 8, 2005 | 06:32 AM
cleveland_guy24's Avatar
I've had good luck so far with the VXI caliper paint from Autozone. I didn't mask, I just sprayed into a paper cup and applied with small acid brushes. If you do it this way, just make sure you have plenty of light and take your time. If you work a small section, it seems to level fine.
Make sure you try to get the caliper as clean as possible before you start painting so the paint has a good surface to adhere to. You can use brake cleaner (be careful and don't get it on painted surfaces), or even some simple green and a brush and some elbow grease. Good luck!
Old Mar 8, 2005 | 06:36 AM
Hockey's Avatar
Definitely go to decalgirl.com for the G2 kit and vinyl decals.
They are great with customer service, and the products are top quality.
I've used the G2 kit on nearly 20 different cars!!
*grind down those seams and file em smooth for the best results.
-Hockey
Old Mar 8, 2005 | 07:53 AM
David1's Avatar
I have had the G2 on now for a couple years and it is time for a touch up. I got the brakes so hot on the track (I went through the factory pads within 100 miles)that the paint actually burned and then flaked off when I hit the calipers with a stream of water. It is very durable for street use and the track if you don't overheat the brakes.
Old Mar 10, 2005 | 02:53 AM
LouisM's Avatar
Am definitely thinking abouit painting the calipers on my MY05. I have seen some references to putting the car up on stands to do this. Why? Is it just a convenience issue or is there some compelling reason to jack up the car? Thank you.
Old Mar 10, 2005 | 09:16 AM
E White's Avatar
... it is best to do it with the wheels removed.
Old Mar 10, 2005 | 09:27 AM
Nishant's Avatar
i was going to paint mine as soon as it got a lil warmer but now i am not sure. thoughts from avid trackers? i know i have overheated my pads and i use Cobalt VR Specs
