Camber kit
Old Dec 1, 2004 | 11:02 AM
D-S2K's Avatar
Default Camber kit
i'm going to get some lowering springs on the car to give it a slight lowered look and better handling. would i need a camber correction kit to correct any negative camber after the installation of the springs?
btw, which springs should i go with?
Old Dec 1, 2004 | 11:07 AM
s2000_boi336's Avatar
In my opinion, I think you shoudl go with theTein S-tech lowering springs
Old Dec 1, 2004 | 11:46 AM
sanee515's Avatar
i have buddyclub coils. and the rear have -2 camber. is a camber kit required for that degree of negative camber? will it significantly wear out your tires due to camber?
Old Dec 1, 2004 | 12:27 PM
Ludedude's Avatar
Administrator
No camber kit is necessary to get -2 degrees front or rear. The car is set up for adjustable camber from the factory.
Old Dec 1, 2004 | 12:32 PM
revhi's Avatar
Thats the degree of camber you want. Yes it will wear faster unless you can do large figure eights everytime you drive.
Anymore camber, your car will not handle as well.
Old Dec 1, 2004 | 12:35 PM
Jimmy325's Avatar
No, you do not need camber kits for that kind of camber.
Remember, it's not the camber the ruins the tires, it more
the toe that affects tire wear. How do you like your buddy clubs?
At the softest setting, is it like stock or stiffer than stock?
How stiff can it go? Rock hard stiff?
solomon
Oct 7, 2005 01:37 PM
KaNgArOo
Sep 24, 2005 03:59 PM
kwokdezz
Nov 10, 2004 01:26 PM
vvtli78k
Mar 25, 2004 10:29 PM
S2KEvolution
Jul 15, 2003 06:11 AM
