camebr,toe,caster
Old Sep 5, 2007 | 08:59 AM
pinoyk20's Avatar
Default camebr,toe,caster
hi guys can we adjust the the camber,toe,caster alignment on our s2000??? how do we adjust it???? can the stock oem parts be adjusted or we have to buy aftermarket parts to adjust it??? specially the cambert.......... sorry noob question....... thanks!!!!
Old Sep 5, 2007 | 09:16 AM
[AP2-2NV]'s Avatar
everything is adjustable.
Old Sep 5, 2007 | 09:29 AM
pinoyk20's Avatar
front and rear camber,toe,caster algin all adjustable??????
Old Sep 5, 2007 | 09:30 AM
[AP2-2NV]'s Avatar
yep. and very adjustable. gives you a very wide range of adjustment.
Old Sep 5, 2007 | 09:33 AM
pinoyk20's Avatar
thanks !!!!!! how do you adjust the camber???
Old Sep 5, 2007 | 09:43 AM
[AP2-2NV]'s Avatar
you take it to a qualified alignment shop and they do it for you.
Old Sep 5, 2007 | 09:48 AM
Gaspode's Avatar
Originally Posted by [AP2-2NV
,Sep 5 2007, 06:43 PM] you take it to a qualified alignment shop and they do it for you.
or ....if you like DIY
Spend tens of thousands of
Old Sep 5, 2007 | 10:02 AM
alejo's Avatar
/\ lol
Old Sep 5, 2007 | 11:22 AM
tinkfist's Avatar
[QUOTE=Gaspode,Sep 5 2007, 01:48 PM] or ....if you like DIY
Old Sep 5, 2007 | 11:29 AM
FormulaRedline's Avatar
Camber on this car is adjusted through the eccentric bolts on the control arms. These bolts connect the arms to brackets on the chassis and have offset cam plates on both the bolt head and nut sides. If you loosen the nut, then spin the bolt, the cam plates adjust the position of the arms. Moving the lower arms out (in) gives you more negative (positive) camber. The rear toe link also has an eccentric bolt, but the front uses the steering arms.
Keep in mind almost all the adjustments are interrelated. For instance, in the rear, if you want to chaneg camebr without changing toe, you have to move both the control arm and the toe link in or out. If you want to change toe without changing camber, you have to move one in and the other out. In the front, throwing caster into the mix makes it even more complicated. With patience, a DIY alignment can be done, but it's not an easy thing to learn if you have no experience aligning cars.
