Can the F20C engine fit into a Honda/Acura...? Advice plz...
Old Nov 23, 2001 | 06:30 PM
QCK HNDA's Avatar
Default Can the F20C engine fit into a Honda/Acura...? Advice plz...
Alright...
I am thinking of getting this older gen civic / teg...and I was wondering if I would be able to drop a S2000 engine into it? Cuz...that would be soo tight!!!!
So...what do you think? Would it work? What would I need to do? How much would it cost? Plz let me know...thnx in advance...!!!!
Old Nov 23, 2001 | 06:43 PM
Schatten's Avatar
well the F20C is a RWD engine that spins the opposite direction, am I correct? so, putting it into a CIVIC, you'd need to build a custom tranny, widen the car a bit, uhmm quite a bit to make things work unless you made the civic/teg into a rwd car which would entail quite a bit of custom suspension work. a lot of bucks would need to be dropped into this project to make it work no matter which direction you would look into.
Old Nov 23, 2001 | 09:22 PM
sumir brahmbhatt's Avatar
to be frank it would cost much more than one s2000
Old Nov 24, 2001 | 01:29 AM
integrate's Avatar
There's a CRX with an NSX motor in it. The NSX motor was put in the rear. Fully race modified.
Here's a link to it.
http://www.mahdavimotorsports.com/images/crx/index.htm
Old Nov 24, 2001 | 06:02 AM
s2ktaxi's Avatar
Aside from engine turning the wrong way, you'd have a problem attaching a transmission to it or finding the right mounting points for it. Then you have to worry about a custom header etc.
For the money you would spend, you could probably trade the old civic in and spend it on an NSX!
Old Nov 24, 2001 | 10:08 AM
malachi's Avatar
it's been done.
it's very expensive (as noted here, far more than an S2000).
Old Nov 24, 2001 | 09:47 PM
Nside's Avatar
Pretty sure that an s2000 is much "tighter" than a civic with an s2000's engine...
Old Nov 25, 2001 | 06:22 AM
Elistan's Avatar
Best bet is to put in a B18C engine. It'll drop right in. Tune it right and you could have 200whp.
Old Nov 25, 2001 | 09:40 AM
lvs2k's Avatar
Hell, I thought a simple coffee can exhaust mod would make the Civic the equal of an S. I've run across a few teenage boys who certainly thought it would.
912S2k
Engine Swaps
Mar 29, 2018 01:39 PM
dyhppy
Nov 10, 2006 02:23 PM
05berlinas2k
Oct 17, 2006 04:55 AM
Honda-S2000VTec
Jul 22, 2003 12:55 PM
Cornfish
Feb 6, 2002 09:33 AM
