S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Can't remove soft top frame from two mounts. (https://www.s2ki.com/forums/s2000-talk-1/cant-remove-soft-top-frame-two-mounts-787465/)
Ellington May 7, 2010 09:56 AM
Hey, I'm in the process of removing my soft top in order to save weight. I have everything out, but I'm stuck because I can't figure out how to seperate the soft top frame from the two mounting brackets on each side of the vehicle. Anyone know how to do this?
Thanks
davgoat May 7, 2010 10:28 AM
If you have the motors out and the 5 bolts on each side of the frame it should lift out. you need two people to really lift frame off. You have also removed all the metal from the back side were the top rain seal is?
Ellington May 7, 2010 07:46 PM
I'm an idiot. I was trying to do something that was unecessary... Thanks for the help. I got the soft top out and the hard top back on!
trebor8915 May 7, 2010 09:39 PM
I have to do this soon. Not looking forward to it.
s2k dre May 8, 2010 05:32 AM
i done it plenty of times. One hour tops with pullin the interior 5 bolts on each side of the frame and it comes right out.
TougeS2k May 8, 2010 06:41 AM
Ya you know a DIY write up would be AWESOME. I def plan on doin this in the future when i have a DD and can drop some $$ on a CF top.
Ellington May 9, 2010 10:46 AM
I used an EXCELLENT DIY written by cyclone36. It's under the DIY section under Robbins Top install. You just follow the steps that he has listed until the top is gone. The only additional step is removing the soft top motors. All you have to do is remove two plates on each side of the vehicle an the whole frame (motors and all) comes right out pretty easily. Hit me up if you need any help when you get around to it. I love having the soft top out.
trebor8915 May 10, 2010 10:31 AM
^Does the DIY apply for the EZon top as well?
Ellington May 10, 2010 06:25 PM
The write up is specifically for the Robbins top, but I would GUESS that most of the steps are pretty darned similar. It's a damned thorough write-up.
© 2026 MH Sub I, LLC dba Internet Brands
