Can't remove soft top frame from two mounts.
Old May 7, 2010 | 09:56 AM
Ellington's Avatar
Default Can't remove soft top frame from two mounts.
Hey, I'm in the process of removing my soft top in order to save weight. I have everything out, but I'm stuck because I can't figure out how to seperate the soft top frame from the two mounting brackets on each side of the vehicle. Anyone know how to do this?
Thanks
Old May 7, 2010 | 10:28 AM
davgoat's Avatar
If you have the motors out and the 5 bolts on each side of the frame it should lift out. you need two people to really lift frame off. You have also removed all the metal from the back side were the top rain seal is?
Old May 7, 2010 | 07:46 PM
Ellington's Avatar
I'm an idiot. I was trying to do something that was unecessary... Thanks for the help. I got the soft top out and the hard top back on!
Old May 7, 2010 | 09:39 PM
trebor8915's Avatar
I have to do this soon. Not looking forward to it.
Old May 8, 2010 | 05:32 AM
s2k dre's Avatar
i done it plenty of times. One hour tops with pullin the interior 5 bolts on each side of the frame and it comes right out.
Old May 8, 2010 | 06:41 AM
TougeS2k's Avatar
Ya you know a DIY write up would be AWESOME. I def plan on doin this in the future when i have a DD and can drop some $$ on a CF top.
Old May 9, 2010 | 10:46 AM
Ellington's Avatar
I used an EXCELLENT DIY written by cyclone36. It's under the DIY section under Robbins Top install. You just follow the steps that he has listed until the top is gone. The only additional step is removing the soft top motors. All you have to do is remove two plates on each side of the vehicle an the whole frame (motors and all) comes right out pretty easily. Hit me up if you need any help when you get around to it. I love having the soft top out.
Old May 10, 2010 | 10:31 AM
trebor8915's Avatar
^Does the DIY apply for the EZon top as well?
Old May 10, 2010 | 06:25 PM
Ellington's Avatar
The write up is specifically for the Robbins top, but I would GUESS that most of the steps are pretty darned similar. It's a damned thorough write-up.
liquidgsr
Jun 6, 2012 01:36 PM
JDM_JOE
Apr 23, 2012 08:54 PM
s2kc's
Apr 6, 2010 04:54 PM
Whoabitchin
Mar 23, 2010 12:52 PM
Tyraid2K
Jun 10, 2005 03:41 AM
