car hitting rev limiter way too early???
Old Nov 24, 2002 | 07:25 AM
LarryD's Avatar
Default car hitting rev limiter way too early???
Any one ever experience this? Three times now (2 in the rain once one a beautiful day) my car has seemed to bounce of the rev limiter. The 2 times in the rain were at very low RPM's and the car almost seemed like it was sputtering or a cylinder cutting out. This morning one a hard, straight pull the motor acted just like it has when its bounced off the rev limiter at 9k but it happened at 7. I've checked everything obvious under the hood and cant find anything amiss. Any ideas?
btw, the car is totally stock.
thanks!
-LarryD
Old Nov 24, 2002 | 07:33 AM
boiler's Avatar
[QUOTE]Originally posted by LarryD
[B]Any one ever experience this?
Old Nov 24, 2002 | 11:33 AM
TepEvan's Avatar
Originally posted by boiler
When the engine isn't warmed up completely (this means seeing three bars on the temp indicator) and you try to engage VTEC, between 6000 and 7000 rpm, the rev limiter engages and it's like running into a brick wall.
This has happened to me before in first gear pulling out of work (luckily noone was around to see) and it sounds like your problem as well?
Old Nov 24, 2002 | 01:04 PM
Incubus's Avatar
Very harsh rev limiter. I didn't know about it until I tried to take off in my brother's Prelude. The H22 does it too.
Old Nov 24, 2002 | 04:29 PM
Red Blur's Avatar
Temp @ 3 bars = VTEC...
Old Nov 24, 2002 | 04:32 PM
SteveUCI's Avatar
WARM UP THE TRANMISSION TOO!!! That means 6 or 7 minutes of normal driving before WOT VTEC.
Old Nov 24, 2002 | 04:42 PM
LarryD's Avatar
wow, I didn't know about the rev limiter engaging at 7k when not warmed up... interesting, what a great safety feature. As far the water in the ignition problem, anyone know how I can check?
Old Nov 25, 2002 | 07:47 AM
boiler's Avatar
[B]wow, I didn't know about the rev limiter
Old Nov 25, 2002 | 07:58 AM
countach's Avatar
Oh no! Another one... I remember a post like this a few month ago...
Ok, stay driving that way, maybe your car will last at 10K miles if you are lucky..
It's only common sense. Let it warm.
Old Nov 25, 2002 | 08:03 AM
hoof's Avatar
One thought on the low rpm stuttering ... you do realize that in the rain 1st (and sometimes 2nd) will *spin* the tires? I find that full throttle in 1st on wet pavement will always break the tires loose, which causes a very unsmooth acceleration and rpm change. Usually this happens form me in VTEC. I'm wondering if this is what you're experiencing.
