car jack points.
Old Sep 2, 2008 | 01:20 PM
tntrac's Avatar
Default car jack points.
Guys,
I will be changing the engine oil tonight. Is the crossmember (center of car) very distinct? Something I cannot miss? I don't want to raise up the wrong part.
Also, for the jack stands support location, its the metal piece thats on the outer edge near the door?
I have done springs installed, exhaust, etc on other cars but those are in the past.
Sorry, I don't have the manual.
Thanks,
Tony
Old Sep 2, 2008 | 01:39 PM
PJCC's Avatar
The chassis and crossmembers are easily identified. The jack points even easier. You will not miss them if you take 5 seconds to find them.
Old Sep 2, 2008 | 02:19 PM
tntrac's Avatar
Thanks.
Tony
Old Sep 2, 2008 | 02:55 PM
JeremyStone's Avatar
There are 2 jack point looking things in the front. I think you want to use the one more toward the center of the car.
Also for some reason this car likes to shoot the oil out farther than my previous cars. Make sure to move the drain pan a little farther out at first.
Old Sep 2, 2008 | 06:46 PM
tntrac's Avatar
If the jack doesn't fit, can you just lift the side of the car with the jack first then go to the other sides and complete the process. This way, I don't have to use the center location.
Tony
Old Sep 15, 2008 | 12:11 PM
Hornblower's Avatar
Is it OK to jack on the rear diff hub, right under where the drain plug is located?
Old Sep 15, 2008 | 01:13 PM
Incubus's Avatar
...and make sure to move it back when it starts dripping straight down.
Old Sep 15, 2008 | 03:29 PM
gtg749m's Avatar
yes i have done it many times
Old Sep 15, 2008 | 11:19 PM
RFCR's Avatar
Does the service manual show the exact safe jacking points?
Old Sep 16, 2008 | 07:11 AM
vtec9's Avatar
That IS the rear central jacking point. Use it.
