car keeps popping out in second gear
Old Sep 2, 2003 | 03:19 PM
thk's Avatar
thk
Default car keeps popping out in second gear
hi.
This is my first post...I have a '03 model, with around 2k miles on it...engine was properly broken in and all. I have a slight problem though....in second gear, the shifter would sometimes pop out when going downhill or on bumpy roads. It would sometimes happen during acceleration and deceleration. I took it to the dealer in Pasadena, but they said they wouldn't fix it unless I or they can replicate the situation...what should I do about it now? Thanks.
P.S...its happened to me about 10 times already.
Old Sep 2, 2003 | 03:33 PM
3ngin33r1's Avatar
Although I've never had this problem with my '03, the service people at the dealer are correct, it's hard for them to fix a problem they can't see or reproduce. If you can consistanly reproduce the problem under the conditions you specified, you should be able to setup a time that YOU can take the tech for a drive and show them. I wouldn't trust them to reproduce it on their own time.
Old Sep 2, 2003 | 03:39 PM
IronHondaS2000's Avatar
There is a TSB out for this, but it's out for MY01 and MY02's. It could also apply for SOME early MY03's, but I'm pretty sure that Honda rectified this problem with the MY02's. If this has been a persistant problem, you need to get it fixed. Personally, if I owned an S2000, and this happened more than once (or with any car), I would have that car to the dealer so fast...Someone with more knowledge of the TSB's correct me if I"m wrong, but isn't this a common complaint?
~ Ryan
Old Sep 2, 2003 | 03:44 PM
3ngin33r1's Avatar
Bulletins for 2003 Honda S2000 L4-1997cc 2.0L DOHC AP1 (VTEC) MFI
Service Bulletins
TSB Number Issue Date TSB Title
00-049 APR 03 Antitheft System - Type 2 System Operation/Programming
01-008 APR 03 Body - Driver Window Won't Go All The Way Down
98-011 APR 03 Keyless Entry - Transmitter ID/Programming
03-023 APR 03 Body - Convertible Top Creaks/Pops/Rattles on Rough Road
03-020 MAR 03 Engine Controls/Emissions - OBD II DTC's & Monitors
03-014 FEB 03 Body - Convertible Top Cover Snap Broken
03-012 FEB 03 Interior - Center Console Lifts Up in the Back
No second gear problem listed for the '03. Doesn't mean that a problem doesn't exist, just means that Honda hasn't recognized it publicly.
Old Sep 2, 2003 | 04:14 PM
1Fast99Si's Avatar
My car popped out of 2nd gear once when i hit a bump. It is an 03 as well.
My top makes noises when I go over bumps. What could the dealer do to eliminate this creeking? Sorry to hijack the thread, i just never knew there was a TSB for it on the 03's. Has anyone taken their car in for this roof rattle TSB?
Old Sep 2, 2003 | 04:18 PM
3ngin33r1's Avatar
Not that I know of, maybe you could be the first. If there's a TSB and you notice the problem, they should fix it for you.
Old Sep 2, 2003 | 04:29 PM
RazorV3's Avatar
[QUOTE]Originally posted by thk
[B]hi.
Old Sep 2, 2003 | 04:36 PM
3ngin33r1's Avatar
Also, (not that I'm questioning your manual transmission shifting ability) are you sure you are all the way in second gear when this happens? You do only have 2k miles on the vehicle and it can sometimes take some getting used to on the operation if you're not familiar with it's design function.
Old Sep 3, 2003 | 04:44 AM
Kev-MN's Avatar
Hmm, I've got a '03 that has popped out of 4th gear. It goes in next week. It has only done it three times in 4500 miles.
Old Sep 3, 2003 | 09:36 AM
RazorV3's Avatar
do you guys like to rest your hand on the shifter? this puts premature wear on your synchros and can cause the shifter to pop out.
