Changing my oil..
Old Jun 5, 2006 | 08:31 AM
react's Avatar
Default Changing my oil..
I searched, how many quarts of oil should I put in? I bought 5 of synthetic..
Old Jun 5, 2006 | 08:37 AM
RadioZero's Avatar
RTFM
Old Jun 5, 2006 | 08:44 AM
Squeezer's Avatar
5.6 quarts if replacing the oil filter.
Old Jun 5, 2006 | 08:58 AM
Wisconsin S2k's Avatar
it can take as little as 5 and as much as 6. only way to tell is to change it and check the oil level.
Old Jun 5, 2006 | 09:08 AM
afwfjustin's Avatar
I've found about 5.2 or so.
Old Jun 5, 2006 | 09:21 AM
GranPrix's Avatar
i did 5 and i have more than enough.
check it a couple of days later and then a week later and that's with a filter change also.
Old Jun 5, 2006 | 10:05 AM
PrimoGen's Avatar
my helms says 5.3 for refills and 5.9 on a fresh mototr build
Old Jun 5, 2006 | 10:24 AM
vtec9's Avatar
[QUOTE=Wisconsin S2k,Jun 5 2006, 11:58 AM] it can take as little as 5 and as much as 6.
Old Jun 5, 2006 | 05:30 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
On the s2k oil changes I've done (300 +) They take about 5.8 quarts. 6 quarts puts it barely above the top X. I always put 6 in mine.
HOWEVER.....the car sits for over two hrs with the plug out while I'm working on other stuff, and the car slightly up in the rear and tipped to the passenger side.
Many variables to changing oil. Best advice is (if your doing oil and filter) is to put 5 in, run it for 20 seconds, shut it back off and check it.
Old Jun 5, 2006 | 05:32 PM
revS2k's Avatar
Mine was exactly 5 and I added a little more during the week.
