check engine light?
Old Oct 7, 2002 | 07:43 PM
b8b88's Avatar
Default check engine light?
Is it normal that the check engine light is on? When I have changed the straight pipe even though I put back the oxygen sensor?
Old Oct 7, 2002 | 08:21 PM
BlackS2000Turbo's Avatar
Explain "when I have changed the straight pipe". Do you mean you put a pipe in to bypass the cat?
Old Oct 7, 2002 | 08:30 PM
b8b88's Avatar
I took out the cat converter and replace a pipe. On the pipe they drilled a hole to put in oxygen sensor. First two hours I drove around didnt have any problem, but later on, check engine light is on, so I dont know if that is normal?Will I hurt my engine?? or anything else??thanks for the reply
Old Oct 7, 2002 | 09:45 PM
GHS2K's Avatar
YO!!!
Maybe you REV your car too much Man!!!
LOL
Old Oct 7, 2002 | 10:12 PM
xviper's Avatar
Did they just "drill" a hole for the O2 sensor or did they put an adapter on to raise the sensor out of the exhaust flow and get it farther from the heat? If not, your sensor probably got cooked.
Old Oct 7, 2002 | 10:51 PM
b8b88's Avatar
they put a adapter on it, but the check engine light is on when I drove couple hours later. Did I damage anything? I still have the original cat converter. Should I change back? But I like the straight pipe tho
Old Oct 8, 2002 | 04:27 AM
You need not worry. The worst that will happen is you'll get sick of the light being on. The O2 sensor that mounts in the cat is the secondary O2 sensor. It basically monitors the cat. The light that sensor throws to the ecu doesn't put the car in to a "safe mode". If you had an OBD2 you would get a "deteriorated catalytic converter" error. The primary O2 sensor mounted in the header is the one responsible for adjustment of the air fuel ratio. You'll eventually get used to the light... I did!
Old Oct 8, 2002 | 07:50 PM
b8b88's Avatar
But is there anyway to bypass the check engine light? Because later on, if my engine really have some problems, I wont know it right. Since the light is always on
Old Oct 8, 2002 | 07:55 PM
xviper's Avatar
I don't think you can bypass the CEL as it is only an indicator of something the ECU finds out is wrong. You need to "fool" the computer into thinking that the O2 sensor is giving correct signals. Where there's a will, there's a way. You'll need to find some electronic gizmo that will feed a constant "good" signal through the sensor wire. Beyond that, I don't know. But I seem to remember seeing that some guys with straight pipes don't get the CEL. Can't remember how they did it.
Old Oct 8, 2002 | 10:54 PM
b8b88's Avatar
thanks
