checking oil level when engine is cold
Originally posted by Sev
Exactly what Cdelena says, and to just add to it, make sure the car has been off for 3-4 hours so all the oil is in the pan. Otherwise you will get a bad reading.
[/B]
[/B]
Originally posted by josh3io
if that's true then what's the point in checking the oil when you gas up? i usually don't hang around for 3-4 hours at the pump... [/B]
Howevere, if you want to know EXACTLY how much oil you have its better when it is completely cold as ALL the oil in tour engine gets a chance to drain into the pan.
Originally posted by DJHohum
...BTW i dont know but in the manual it said to check the oil just a few minutes after the engine was running, is that why it read so low, cause the engine was cold?
Thanks MIke
Thanks MIke
BTW, it is NORMAL for the S engine to consume oil during break-in, so don't worry. Just check your oil more frequently and fill it up as needed.
DJHOHUM:
Follow the manual! The reason to check it "warm" is oil changes vicosity at various temperatures. It expands and is thicker at low temperature, just like water turning to ice (as an exagerated example). Honda has calibrated the stick for warm oil...so measure it warm. As for overfilling, the reason to avoid this is "cavitation". To much oil may cause cavitation which results in air in the oil. Air in the oil means lower oil pressure. Lower oil pressure means heat carrying capacity to remove heat from the lubrications system. Many folks have had natural consumption of large amounts. It's normal! Just keep an eye on it.......
P.S. I lived in San Dimas (Cataract Ave) for 10 years until I transferred to Utah. Stop in at the Casa Del Rey and tell Art (the owner) hello from me. His brother used to be my room mate. My other friend owns the Comfort Suites just down the road on Arrow Highway. Drop me a line.
Ok Ladies.
Lets try this.
Someone go outside and measure the oil level in their cold car.
Then start the car, let it get hot and then measure the oil again...
then go for a drive, measure it again.
Problem Solved...
Lets try this.
Problem Solved...
It's really basic physics. Agree the difference is slight but it's there. You say it doesn't matter....does this mean you know more about oil viscosity and measurement then Honda? If you really want to get into it, in addition to the thermal expansion issue, the miniscus (related to viscosity) on the stick is reduced at higher temperature resulting in a flat line across the stick and thus a more accurate reading. Sorry you think it's bull but what do you do for a living if I might ask? I am an engineer and understand physics and fluid dynamics (hydraulic systems) very well
Originally posted by wirejock
OK as long as we're on the subject. Which side of the dipstick is correct. The passenger's side is almost 1/2 quart higher than the driver's side of the dipstick. I'm assuming the passenger (higher) side is the correct reading.
If so, I'm ok.
If so, I'm ok.
[Edited by Big Al on 02-19-2001 at 05:34 PM]
