Chirping from 1st to Second
Old Mar 22, 2001 | 10:23 PM
4IGS2000's Avatar
Spammer
How many of you out there are able to chirp from first gear to second gear??? I've down it downshifting a couple of times. Only once i did it from 1st to second.
Old Mar 22, 2001 | 10:27 PM
Aft3rburn's Avatar
even a 6000+rpm upshift and quickly letting out the clutch? c'mon man! it's gotta chirp! Hell even my Conto can do it! SOMETIMES, it'll do a 2-3 chirp...Never has done a 3-4 chirp
Old Mar 22, 2001 | 10:31 PM
Schatten's Avatar
I can usually do it at will. notta problem here.
Old Mar 22, 2001 | 10:39 PM
malachi's Avatar
why would you want to?
Old Mar 22, 2001 | 10:55 PM
4IGS2000's Avatar
Spammer
It sounds cool, hmmm guess im not use to those rubbering things that my foot gets stuck too, the prelude was easier
Old Mar 23, 2001 | 12:27 AM
DavidM's Avatar
Mine chirps from 1st to 2nd when you shift fast enough and at the redline.
Old Mar 23, 2001 | 06:36 AM
STL's Avatar
STL
You fellas getting all these chirps...what tires are you running?
My car is still on stock rubber (with only 2,7xx miles) and I have a strip on the way to work where I almost always take 1st gear up to 8500-9000rpm before shifting very quickly. Today I did it on 2nd and 3rd gear as well. I've done this many many times and I've never heard the tires chirp. I was under the impression chirping was something you got from tires that have a harder rubber compound (and that our S-02s probably wouldn't be making much if any noise).
Making your tires chirp, while sometimes kinda cool, really means your tires are loosing grip which usually isn't a good thing (if you're trying to go fast).
Old Mar 23, 2001 | 06:40 AM
Unicron's Avatar
4igs2000,
I had some loud chirps when I was running Yokohama Parada's in the rear (harder rubber).
Now, with my Toyo Proxes T1-S...I just feel alot of wheel spin when I 1st to 2nd. It chirps sometimes depending on the temperature of the tread and the road surface I guess. I got a 3rd to 4th gear chirp though when I was racing a M3.
I went back to my stock wheels the other night...and same thing...I would get some wheel spin from 1st to 2nd...but no chirp.
Old Mar 23, 2001 | 06:47 AM
Schatten's Avatar
stock S02's, about 8K miles - no tread now, so its obvious how I can chrip at will. <g>
Old Mar 23, 2001 | 07:03 AM
DavidM's Avatar
3500km on my car and tyres ... so running totally stock standard (ie. 225/50/16 S02s).
