Clicking when starting from a stop
Old Aug 14, 2008 | 12:25 PM
chhatre9's Avatar
Default Clicking when starting from a stop
Hi all, I have noticed a clicking sometimes when I start from a stop. I hear it coming from the outside of the car, not inside. It only is a few clicks, and does not happen all of the time. I maintain the car as recommended in the manual. It doesnt seem to drive differently, but I am very worried about it being an axle or differential. I have 29k miles on it, with diff fluid changed at 21k. I do not track it, but spirited driving, of course. No FI or engine mods. I have a busy work schedule this month and I don't want to F with dealers poking around trying to figure it out and run up the bill, but I also want to fix this before warranty runs out.
Please help!
Old Aug 14, 2008 | 01:03 PM
SCCS2K's Avatar
Sigh...did you search? At all? This question comes up about once a day.
Retorque your axle nuts to 220lb.ft., problem solved. May as well get new ones while you're at it, they're cheap.
Old Aug 14, 2008 | 03:10 PM
RTZX9R's Avatar
what fluid did you put into the diff?
Old Aug 14, 2008 | 03:15 PM
SCCS2K's Avatar
That wouldn't cause a single click upon starting to move. That's the well-known hub nut TSB. It's a $30/30-minute job. Most of us have had to do it at least once.
Old Aug 14, 2008 | 03:53 PM
NNY S2k's Avatar
Last year I retorqued the old nuts, that only fixed the problem for a short time. Put new ones on this past spring, along with the axel grease and everything has been good as new since.
Levi
Old Aug 14, 2008 | 04:05 PM
Mrfixit687's Avatar
The tsib is for older cars isnt it? The newer cars should have it fixed already. http://www.alldatadiy.com/TSB/24/062446b7.html Theres no axle tsib for an 06, however that doesnt mean that isnt the problem.
Old Aug 14, 2008 | 07:18 PM
chhatre9's Avatar
Fluid is whatever Honda uses - I did it with them. I did have tires changed recently - so I need to replace axle nuts or re-torque them?
chhatre9's Avatar
Also, is there a safety issue while driving?
Old Aug 14, 2008 | 07:25 PM
SCCS2K's Avatar
Yeah, do a search if you need more info...super common. I believe there's a scan of the TSB here too.
The nuts are only a few bucks each, so you may as well get new ones. The key thing is to retorque to 220lb.ft.
Old Aug 14, 2008 | 07:26 PM
SCCS2K's Avatar
nope. not under any normal circumstances.
