Clutch pedal went to the floor.
I'm not an expert, but ive already had this happen with my s as well, and a previous accord - both of which i let one too many people drive. I refilled the fluid as well this past week and havent had any problems with it going to the floor, even though it never originally did. Try flushing it and refilling the cylinder, if still not, maybe the clutch has gone bad o.O. Btw are you the original owner or did you just buy it?
It works now its just that I had to pump it when I got in the car today it feels a little mushy but I'm going to try flushing it see if that helps. I got the car about a year ago just hit 90000. Btw are there any writeups on flushing clutch fluid?
also you might wanna check the line if your dad was rough on the clutch he could have possibly caused a small leak in the line, this could be a long shot considering those lines are pretty strong, but from what it sounds like because of the mushiness does it go into gear fine?
He wasnt really that hard on it he only stalled the once but ya it goes into geat fine and I cant notice it leaking from anywhere I looked at the master cylinder inside the car and noticed a small amount of an oily substance on the tip of it but there were no spots that looked like it was dripping.
Are you leaking fluid, or was it just low once. It sounds like you ran out of fluid at the master cylinder and then got air in the line. If that's true, you need to bleed the line. Unless you've at least bled brakes before, don't try it yourself, get a shop or mechanic friend involved. It's not that complicated, but there's plenty of easy ways to screwup and make it worse.
If you're actually leaking fluid then start pumping the pedal and looking for drips.
